Re: My bracket hemi build
[Re: MattW]
#2027180
03/08/16 12:28 PM
03/08/16 12:28 PM
Triple Threat
Renton Washington
You can't post without pictures! !!!! I live my life vicariously! !!!!!! Come on.lol Matt Hahaha, I'll snap some pictures tonight.
[Re: Triple Threat]
#2028265
03/10/16 12:14 AM
03/10/16 12:14 AM
Posts: 3,519 pacific northwest
Stroker Scamp
pacific northwest
Nice, did you port that manifold or someone else? Looking forward to seeing it run!!
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Stroker Scamp]
#2028517
03/10/16 12:57 PM
03/10/16 12:57 PM
Triple Threat
Renton Washington
Nice, did you port that manifold or someone else? Looking forward to seeing it run!! I did it. Hopefully it works, I'm definitely no porter.
[Re: MattW]
#2029166
03/11/16 12:22 PM
03/11/16 12:22 PM
Triple Threat
Renton Washington
Thanks for the pictures! Was at my friends place and he used my drag pack intake to see how far off the intake openings were. I'm assuming you port matched yours? Was the intake off by much? His was off by almost 3/16 at the bottom. Mind you this was the early 5.7 head that is untouched and the intake is also untouched. Would like to know what its like on the 5.7 eagle and 6.4 appache. Thx Matt I ported it to an Indy Gasket so it would match the heads. Never had a chance to check fitment before that, just went right to it. There was as much as 3/16" like you're saying that needed removed to make for a smooth transition in places, fairly consistent on all ports.
[Re: Triple Threat]
#2031037
03/14/16 04:02 PM
03/14/16 04:02 PM
Posts: 8,110 Tulsa OK
Bad340fish
Tulsa OK
Looking Good Dustin, I am going to try and by a hood soon and I want a gen III in the future. I might rethink my scoop now lol.
68 Barracuda Formula S 340
[Re: cagebob1]
#2031377
03/15/16 12:03 AM
03/15/16 12:03 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
not attempting a hi-jack, but how short is the "short" intake? cylinder head to carb flange. looking good! 7"
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Triple Threat]
#2031379
03/15/16 12:06 AM
03/15/16 12:06 AM
sixpackgut
Charleston
That car has a steel hood?
[Re: Triple Threat]
#2031390
03/15/16 12:14 AM
03/15/16 12:14 AM
Posts: 361 Canada
onig
Canada
Where did you get the wiper motor block off plate? What is the width of the engine plate? Did you trim the width at all or is that how it came?
69 Dart
[Re: onig]
#2031597
03/15/16 11:28 AM
03/15/16 11:28 AM
Triple Threat
Renton Washington
That car has a steel hood? It did, will be ordering a glass hood for it once I decide what I want. Where did you get the wiper motor block off plate? What is the width of the engine plate? Did you trim the width at all or is that how it came?
Thanks Bought the wiper block off plate from a website that no longer exists. Motor plate is as delivered from AEI, It could stand to be about an inch wider and taller. The Milodon pan will hit the K frame if you set it on the rails.
[Re: Triple Threat]
#2031779
03/15/16 04:24 PM
03/15/16 04:24 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I am very impressed with your project and will do a little write up in the newsletter that I publish. Personally, my bracket beast may be one of those that you end up chasing, because I will not be able to run you heads up.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
