I need opinions on high perf dist. tuning options #196849
01/18/09 02:37 AM
01/18/09 02:37 AM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
Howdy
I was going through hell trying to tune my carb to idle well on my 408 stroker. I got some help here and learned a lot about timing and distributors- it was a low initial advance causing my trouble.
Here's my problem- my motor wants 16-20 degrees of timing to run well off idle, but it pings when it approaches full mechanical advance around 3k. I bought the MSD pro billet thinking that their 18 degree mechanical advance bushing would work for me, but as I get the tune closer I'm finding that the motor doesn't want 34 degrees total, maybe more like 30. That leaves me with the same problem I had with the stock distributor- too much mechanical advance.
Judging by the sizes of the mech. advance bushings in the msd kit (.373=18deg, .339=21deg) each degree of timing takes up .011" of slot travel in the distributor's plate. I could weld it up .055" shorter and run 17 initial and 30 total.
I'm wondering if I might be wasting my time trying to get the mech advance down to 13degs? Maybe I should just run the lightest springs or even just one spring and retard the total advance to 30? My concept with this is to basically just use the mech advance for starting and hope it won't detonate off idle. I would want the advance to give me 15deg+ timing at 800rpm idle. I have 4.10 gears and a four speed with a single plane and a mildly rumpity cam, so I'm already not getting good power until 1700 or so.
I'm driving this in the street a lot, so I don't think a locked out advance would work for me.
This is my first v8 build and ground up tune so I need all the help I can get!
Kevin
Re: I need opinions on high perf dist. tuning options [Re: radar] #196850
01/18/09 08:47 AM
01/18/09 08:47 AM
Q
Quicktree Offline
Quicktree  Offline
Q
put the black bushing in it, 1 light silver and 1 light blue spring in it. you should be good to go. set the timing to 34-38* and you will be fine.
Re: I need opinions on high perf dist. tuning options [Re: Quicktree] #196851
01/18/09 01:38 PM
01/18/09 01:38 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Big cams need lots of idle advance. I actually use MP springs in the billet distributors as i find all MSD are too stiff. you want it to advance fast not far
Re: I need opinions on high perf dist. tuning options [Re: radar] #196852
01/18/09 02:57 PM
01/18/09 02:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Mine`s locked and I don`t have the kick-back problems others talk about and I don`t use a retard that actually made it WORSE.
