manual trans parts #1933849
10/17/15 05:42 PM
10/17/15 05:42 PM
SD
Z
zrxkawboy Offline OP
Z
SD
I'm rebuilding the engine in my '57 Belvedere. The transmission works fine, but as long as it's out, I'd like to replace seals/gaskets, etc. (It's a 3 speed manual.) Does anyone know a source for these parts? Bernbaum lists parts through '56 only. NAPA lists a rear seal and a couple of bearings. It would be nice to buy a seal/gasket kit if possible. Thanks!
It's Swifty! Swifty, you toad sucker!
Re: manual trans parts [Re: zrxkawboy] #1968219
12/12/15 05:03 AM
12/12/15 05:03 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
try brewers im sure he can point u in the right direction if they cant cross refrence the parts
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: manual trans parts [Re: zrxkawboy] #1968320
12/12/15 12:57 PM
12/12/15 12:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.bestgasket.com/drive_train_part_info.asp?DriveTrainType=Transmission%20Set%20%28standard%29
Don't be the exception.
