Dana wheel bearing adjustment #1967984
12/11/15 10:00 PM
12/11/15 10:00 PM
Saskatchewan, Canada
barracudabob Offline OP
Changing rear axle seals in my 75 Dodge 200. Its got a Dana with floating axles. Whats the procedure for adjusting the wheel bearings, i.e. how tight should the inner be, and then the lock nut. Thanks in advance, Bob
Re: Dana wheel bearing adjustment [Re: barracudabob] #1968067
12/11/15 11:53 PM
12/11/15 11:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've always tightened them about the same as I would front wheel bearings. Don't know if its right, but I never had an issues with them. I may have been very lucky....Gene
