Re: Correct way to wire battery and cut off switch
[Re: 71Pan]
#1967597
12/11/15 07:53 AM
12/11/15 07:53 AM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Make sure you use around a 200 amp disconnect switch if you are using it for everything. Some are rated like 20 or 30 amps and they fail. Alternator wire goes to battery otherwise car keeps running when disconnect switch is shut off. This one would be the minimum I would use....... http://www.summitracing.com/int/parts/mor-74101/overview/
[Re: 71Pan]
#1967620
12/11/15 10:56 AM
12/11/15 10:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Make sure you run large enough wire from the alt to the battery based on the size of the alt and the length you are running.. and yes it gets mounted on the battery side of the shut master switch
[Re: J_BODY]
#1967648
12/11/15 12:09 PM
12/11/15 12:09 PM
MR_P_BODY
hindsight, being what it is, I wish I would have used one of those "push/pull" levers and mounted the switch in the truck instead of putting a hole in the back panel of the car. On the race car I did mount the switch inside with the long lever but on the Rampage its mounted on the bumper.. I dont like drilling holes in the sheet metal unless its a MUST... you can see it on the right side of the bumper EDIT A tip if you mount the switch with the arm on it.. set it up so you PULL the arm to turn it on.. if you do it the other way(push for on) you can shut it off IF the car launches hard.. just the weight of the arm can turn it off
[Re: J_BODY]
#1967656
12/11/15 12:21 PM
12/11/15 12:21 PM
Posts: 7,506 Az
Crizila
Az
hindsight, being what it is, I wish I would have used one of those "push/pull" levers and mounted the switch in the truck instead of putting a hole in the back panel of the car. That's what I used. Flaming river makes a nice one. Mine is located just under the bumper and batt. charge plugs
Fastest 300
[Re: 71Pan]
#1967674
12/11/15 12:44 PM
12/11/15 12:44 PM
Posts: 430 Michigan
HR3128
Here's one way of doing it. This eliminates a hot wire running all the way to the front of the car when the disconnect switch is off.
[Re: HR3128]
#1967683
12/11/15 01:00 PM
12/11/15 01:00 PM
MR_P_BODY
One thing I did on the alt hot line was to put a 100 amp fuse at both ends of that lead.. just in case it were to short out some how.. with both ends fused if it shorted out anywhere on the wire it would blow one of the fuses.. my alt is a 85 amp Denso
[Re: 71Pan]
#1967693
12/11/15 01:16 PM
12/11/15 01:16 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
How about a 4 terminal switch like the one Speedway sells? http://www.speedwaymotors.com/Four-Post-Battery-Disconnect-Switch,6967.html I'm doing some re-wiring on the Savoy and I'm looking at this switch to replace the basic Moroso 2 post unit. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1967701
12/11/15 01:30 PM
12/11/15 01:30 PM
MR_P_BODY
How about a 4 terminal switch like the one Speedway sells? http://www.speedwaymotors.com/Four-Post-Battery-Disconnect-Switch,6967.html I'm doing some re-wiring on the Savoy and I'm looking at this switch to replace the basic Moroso 2 post unit. Gus That switch works well.. just use the field wire on the small terminals
[Re: MR_P_BODY]
#1967822
12/11/15 04:42 PM
12/11/15 04:42 PM
markz528
Morrow, OH
One thing I did on the alt hot line was to put a 100 amp fuse at both ends of that lead.. just in case it were to short out some how.. with both ends fused if it shorted out anywhere on the wire it would blow one of the fuses.. my alt is a 85 amp Denso Agree - I did the same.
[Re: MR_P_BODY]
#1967836
12/11/15 05:35 PM
12/11/15 05:35 PM
Posts: 7,506 Az
Crizila
Az
One thing I did on the alt hot line was to put a 100 amp fuse at both ends of that lead.. just in case it were to short out some how.. with both ends fused if it shorted out anywhere on the wire it would blow one of the fuses.. my alt is a 85 amp Denso Smart! Mines only fused on one end. Gotta change it.
Fastest 300
[Re: 71Pan]
#1967945
12/11/15 09:18 PM
12/11/15 09:18 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Fused mine also....cheap insurance.
[Re: 71Pan]
#1968318
12/12/15 12:51 PM
12/12/15 12:51 PM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
A nice way to wire the 1 ga. starter is to use a rear solenoid so the big cable is only live when cranking! And when using a disconnect, just put it between the solenoid & battery (+). http://www.madelectrical.com/catalog/tm-1.shtml
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
[Re: 71Pan]
#1968354
12/12/15 02:03 PM
12/12/15 02:03 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I have a continues duty relay on mine mounted to the firewall. Its triggers from my ignition switch but its wires run through my 4 post disconnect. Works great.
I also did the starter solenoid in the trunk. I used a Jeep solenoid that works with the stock neutral safety switch.
68 Barracuda Formula S 340
[Re: shorthorse]
#1968452
12/12/15 04:39 PM
12/12/15 04:39 PM
fourgearsavoy
Rittman Ohio
Gus. I've also done that before. Since your going to run the field wire to the rear and back, you might want to up the wire gauge a bit. Another trick is to get rid of the push on connectors, modify the tabs for small nuts & bolts and use eyelet connectors for the alternator. The factory push on connectors seem OK but I'm still looking for aftermarket connectors that don't spread the first time you push them on. I'm running a Denso Toyota alternator so I have to determine what wire I'm going to run back to the switch Gus
[Re: fourgearsavoy]
#1968474
12/12/15 05:19 PM
12/12/15 05:19 PM
MR_P_BODY
Gus. I've also done that before. Since your going to run the field wire to the rear and back, you might want to up the wire gauge a bit. Another trick is to get rid of the push on connectors, modify the tabs for small nuts & bolts and use eyelet connectors for the alternator. The factory push on connectors seem OK but I'm still looking for aftermarket connectors that don't spread the first time you push them on. I'm running a Denso Toyota alternator so I have to determine what wire I'm going to run back to the switch Gus It really doesnt matter.. one goes to key on side for power and the other is the sense/exciter .. if you have a third wire that is for the dash bulb if it quits working
