AAR Cuda Brake Master Cylinder - Painted? #1953818
11/18/15 06:47 PM
11/18/15 06:47 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
I'm restoring an AAR Cuda and wanted to know if all AAR master cylinders were painted, not painted, or could be both. I have a Bendix master cylinder and booster.
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1953825
11/18/15 06:58 PM
11/18/15 06:58 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Yes, the booster and master cylinder are painted black.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1953827
11/18/15 06:58 PM
11/18/15 06:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The master cylinder, lid, bail, booster & booster valve were all painted as an assembly.
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1953915
11/18/15 08:50 PM
11/18/15 08:50 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Were they painted gloss black or was it gloss with a percentage of flattener added?
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1965584
12/08/15 02:28 PM
12/08/15 02:28 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Can I get a little more information on this issue? I understand the master cylinder was painted black (1970 AAR Bendix) and it would seem like it would have to be a very "hard" gloss paint to stand up to the DOT3 brake fluid but I don't know that for sure. Can anyone confirm that the paint used was "Gloss" and what type of paint would someone suggest with the necessary durability for this application (stand up to the DOT3 brake fluid?
Thanks,
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1965601
12/08/15 02:49 PM
12/08/15 02:49 PM
Canada
Maxwellwedge Offline
Canada
They didn't paint anything to stand up to fluids. They didn't care - lol. I like to paint them (as a complete assy) anywhere from 12-15% flattened.
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Maxwellwedge] #1965613
12/08/15 03:06 PM
12/08/15 03:06 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Maxwellwedge,I was hoping there was a majic bullet, I am restoring this car as show car and would like a way of not having the black paint "lift" a couple of weeks after finishing the project. Thanks
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1965627
12/08/15 03:42 PM
12/08/15 03:42 PM
Canada
Canada
I understand - I use silicone brake fluid in everything these days.
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1965695
12/08/15 05:05 PM
12/08/15 05:05 PM
St. Louis
I
Imrare Offline OP
Imrare  Offline OP
I
St. Louis
Maxwellwedge, makes sense. Whitepost Restorations did the rebuild on my Master Cylinder and they included a note upon shipping it back to me saying do NOT USE synthetic brake fluid because it will deteriorate the rubber parts in the brake system. Ever heard of that?
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1965905
12/08/15 10:13 PM
12/08/15 10:13 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Might be whatever seals and components Whitepost is using that might have a reaction...Never had deterioration from DOT5 in any system I've used it in..
Re: AAR Cuda Brake Master Cylinder - Painted? [Re: Imrare] #1966259
12/09/15 01:31 PM
12/09/15 01:31 PM
Canada
Canada
Never had a problem either.....I think I remember reading that all newer DOT approved brake fluid has to be backwards compatible with all previous ones.....maybe it was in an Ehrenberg article.
