Correct Hemi 727 stamped Part number #196540
01/17/09 09:46 PM
01/17/09 09:46 PM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
What is the correct Hemi 727 1970 part number that would be stamped on the trans?
A guy I met has some 727 transmissions that he says are 70 hemi, but want to verify the factory part numbers as I know the drums and such are different and for what he is asking want to make sure.
Re: Correct Hemi 727 stamped Part number [Re: sawdust] #196541
01/18/09 01:30 AM
01/18/09 01:30 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Well he got the talkin' part done. The numbers don't lie.
Looks like its p/n 3410 671.
1970 440 sx/pk trans is 672.
1971 hemi trans p/n 3515849.
1971 440 sx/pk p/n 850
With some Mopar parts the casting number may be different than the actual p/n but will usually be very close, not sure if this applys to transmissions too. Snatch up if turns out to be any one of the above.
Re: Correct Hemi 727 stamped Part number [Re: sawdust] #196542
01/18/09 01:43 AM
01/18/09 01:43 AM
BFE
blue67440's Offline
blue67440's  Offline
BFE
you need to write down the whole # off the trans pan rail so you can figure out the date code and also note the VIN's if they are stamped on the trannys.
blue
XP29L72 A833 in 881 XP29L72 A727 in 881
Re: Correct Hemi 727 stamped Part number [Re: sawdust] #196543
01/18/09 03:00 AM
01/18/09 03:00 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
I have one sitting in the corner as a table. Tomorrow I'll go out there and get the numbers off of it for ya, to compare.
Ryan
Re: Correct Hemi 727 stamped Part number [Re: Devil] #196544
03/17/09 04:26 PM
03/17/09 04:26 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Here is the stamping on the rail. I didn't even notice the stamping until I took the paint off.
Should the VIN be here somewhere as well?
Ryan
Re: Correct Hemi 727 stamped Part number [Re: Devil] #196545
03/18/09 03:08 PM
03/18/09 03:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A partial VIN will be stamped in the raised pad on the passenger side of the bellhousing.
Re: Correct Hemi 727 stamped Part number [Re: ebodyseast] #196546
03/18/09 03:46 PM
03/18/09 03:46 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Just because the case is a hemi part # doesnt mean it still has hemi internals. I sold a 69 case only, anything could have been put in it.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Correct Hemi 727 stamped Part number [Re: AZ_A12_BEE] #196547
03/18/09 08:06 PM
03/18/09 08:06 PM
Green Lane, PA
sawdust Offline OP
sawdust  Offline OP
Green Lane, PA
Thanks for the info, as it turned out they were not hemi transmissions, what a blessing I did not listen to the "talk".
Re: Correct Hemi 727 stamped Part number [Re: sawdust] #196548
03/20/09 10:34 PM
03/20/09 10:34 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
I am trying to find the listing for all the 904 and 727 trans numbers. Anyone got a link for one?
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Correct Hemi 727 stamped Part number [Re: Rapid340] #196549
03/21/09 01:48 PM
03/21/09 01:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a PDF file of '65-'86 numbers.
http://www.mymopar.com/downloads/transguide.pdf
Re: Correct Hemi 727 stamped Part number [Re: John_Kunkel] #196550
03/22/09 02:05 AM
03/22/09 02:05 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Found the pad...
Good to know that the tranny is the matching one for the Hemi.
Ryan
