Page 3 of 3 1 2 3
Re: 340 verses 360 [Re: 70AARcuda] #196482
01/19/09 06:49 PM
01/19/09 06:49 PM
NY
old340dog Offline
old340dog  Offline
NY
I've got to rebuild my 340 this winter.It has a auto 727. I have considered a 360 instead. Either way it will not be a stock rebuild. Will have some extras. If I decided to swap the 340 out for the 360. What do I have to change? Are the oil pans the same? someone told me I'd have to change the flexplate also. What years are best to look for. And out of what Mopar
old340dog
Re: 340 verses 360 [Re: old340dog] #196483
01/19/09 07:30 PM
01/19/09 07:30 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
oil pan is different in the rear main area...or there is a spacer available so you can use the 340 pan...
you will need a flexplate and damper for a 360.
Tony
70 AARCuda Vitamin C
Re: 340 verses 360 [Re: 70AARcuda] #196484
01/19/09 07:46 PM
01/19/09 07:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes you will either need the B&M flex plate for an external balanced 360 or a torque converter with the weight for the external balanced 360. One or the other NOT both.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Page 3 of 3 1 2 3
