Re: 340 verses 360
[Re: dodger1]
#196443
01/17/09 08:36 PM
01/17/09 08:36 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Heads are basically the same except valve size and that can be changed. The 360 is cheaper to buy and has more cubic inches unless you are strokeing it. Equally built the 360 will make more TQ and dare I say... HP If you are building an A-Body from about 68-71 the 340 tends to add value to a car more so than a 340 because the 340 was the factory performance engine in those cars.
Re: 340 verses 360
[Re: HotRodDave]
#196444
01/17/09 09:05 PM
01/17/09 09:05 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not nessessarly true. 360 's share the head castings with the 340 The 915 heads used in on the 360's in 71 for the most part had 1.88 valves where the 340 in 71 had 2.02 valve heads. 72 up the 1.88 valve heads were prevalent for both and used the same castings. For the most part the valve size is not a major factor until you start running the high RPM range, and the larger 2.02 can can in fact take away low end torque. The 1.88 head will work as well up to about 6000.
Re: 340 verses 360
[Re: MoparforLife]
#196445
01/17/09 09:25 PM
01/17/09 09:25 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
budget wise the 360 is going to be cheaper since there are more pistons available at lower prices...
with everything being equal..the 360 will win...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: 340 verses 360
[Re: 5spdcuda]
#196449
01/18/09 03:12 AM
01/18/09 03:12 AM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
Generally when you have several engines of the same basic design the smallest will make the most power per cube given equal levels of preparation. While this can be an important factor in class racing, when it comes to the street or brackets size matters and big is good. The 360 has several advantages over the 340. 1st. 20 more cubes. 2nd. The bigger mains which are often criticized provide more crank pin overlap which helps even more when using a stroker. IMO most of these engines will never turn enough rpm for the increased bearing speed to become a factor. 3rd. Since all the LA engines share the same deck height and rod length the 360 has a lighter piston than the 340 which is probably at least as important to revabilty as the 340s shorter stroke. 4th. A 4.030 bore size [ a common 360 overbore ] is probably one of the cheapest and commonest ring sizes available. Lastly, cost and availability is much better with the 360. 340s are great for image and restoration, 360s are for making cheap power.
I like the 340's as good as anyone. A 360 is much easier to find and cheaper to obtain. You will come out ahead because of the 20 extra cubes. If you have a 340 Id sell it and get probably two 360's out of the deal. They can make crazy horsepower and torque for reasonable money. save the 340's for the resto crowds. As far as small blocks go, the 340 is a legend but I'll take power anyday
Re: 340 verses 360
[Re: DusterKrazy]
#196450
01/18/09 02:32 PM
01/18/09 02:32 PM
Posts: 4,788 Holland MI Ottawa
2boltmain
Holland MI Ottawa
340s produced for 6 years (only 4 years with the 10 to 1 comp) 360s made form 71 to 2000-2001? 360 prices better due to obvious volume.
Keep old mopars alive.
Re: 340 verses 360
[Re: MoparforLife]
#196453
01/18/09 03:45 PM
01/18/09 03:45 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I'd build a 360 ANY day over a 340. There is nothing magical about a 340...there never has been
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
Re: 340 verses 360
[Re: HotRodDave]
#196455
01/18/09 04:57 PM
01/18/09 04:57 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
What I mean is, taking into account the 340s bore and stroke, there is nothing magical that will give you more horsepower...just because "its a 340". I know for a couple of years, it was in fact the biggest small block Ma had to offer. But there has been bigger and badder since then.
Re: 340 verses 360
[Re: Kindafast]
#196459
01/18/09 06:30 PM
01/18/09 06:30 PM
HotRodDave
Kalispell Mt.
I had one and have known of several others that ran them up to 7000 with no problems. If you are still woried about it buy a steel crank for it, plenty are available for them aftermarket. If you are building a stroker than there is no differance in cost.
Re: 340 verses 360
[Re: HotRodDave]
#196460
01/18/09 06:35 PM
01/18/09 06:35 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I agree there are a lot of a/m parts now for the 360. Back when I was a lot younger #1 no steel cranks were made #2 if they were I could not afford them. Im talking stock from the factory engines. 340 was a stronger higher reving engine.
6.50 @105.26
Re: 340 verses 360
[Re: Kindafast]
#196461
01/18/09 06:45 PM
01/18/09 06:45 PM
MoparforLife
Upper Midwest
No Forged 360 crank - Big deal - Mopars are not noted for crankshaft breakage. Forged or cast. The 360 is not a high RPM oriented engine like a 340. They make it at a lower RPM. Like I said if the 360 would have been made during the non emision ere it would have been 'the small block'. The 340 would not hold a candle to it.
