Cam timing and piston to valve #196396
01/17/09 07:50 PM
01/17/09 07:50 PM
louisiana
sixty9bee Offline OP
louisiana
How much effect does cam timing effect piston to valve clearence?
subject engine is:
0 deck ross flattop 4.15 stroke 400
277 at 0.050 roller cam 700 lift
110 centerline installed at 110
edelbrock heads
Re: Cam timing and piston to valve [Re: sixty9bee] #196397
01/17/09 07:54 PM
01/17/09 07:54 PM
louisiana
louisiana
exhaust valve with no head gasket and 0 lash has contact with piston.
What suggestions to get the minimum clearance? quench is already set for .039 gasket?
Re: Cam timing and piston to valve [Re: sixty9bee] #196398
01/17/09 08:05 PM
01/17/09 08:05 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
You could advance the cam some to get clearance. But if you are hitting, I would flycut valve relief notches into the pistons. I do not feel safe with less than .100 thou on the exhaust to piston.
I know it is more time consuming but do it any way and never have to worry about it.
Old Geezer Racing
Re: Cam timing and piston to valve [Re: sixty9bee] #196399
01/17/09 08:05 PM
01/17/09 08:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the intake at. Advance it 4* and check it again.
I prefer to check it with the head gasket but thats
me. Use a pushrod length checker with 0 lash then
you can figure your lash in
Re: Cam timing and piston to valve [Re: sixty9bee] #196400
01/17/09 08:10 PM
01/17/09 08:10 PM
NC
440Jim Offline
440Jim  Offline
NC
Double check when you change the cam installed position. But as I recall, advancing the cam (going from an intake lobe installed position of 110 ATC to 106 ATC) will reduce intake piston to valve clearance, but increase the exhaust P2V clearance. If you are running 1.5 ratio rockers, it should be around 0.023" change. But the lobe profile can be different than what I am used to.
Let us know what numbers you measure.
I check this when I "map" a cam. And I see around 0.015" lobe lift change with 4 degree advance, measured atg +/- 8 degrees of TDC (that is where min piston to valve usually occurs).
Re: Cam timing and piston to valve [Re: 440Jim] #196401
01/17/09 08:21 PM
01/17/09 08:21 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Good stuff here. I am in the process of chosing a new cam and will be doing this soon, I hope. Beep
Re: Cam timing and piston to valve [Re: Bigbeep] #196402
01/17/09 09:02 PM
01/17/09 09:02 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
if he has contact with 0 lash and no headgasket, he has problems! the question is how much interference is there? also are you sure the cam is in at 110? if you factor .040 for gasket,.020 lash that's still only .060 minus the exact amount of interference. advancing to 106 might help, but not fix the prob.
Re: Cam timing and piston to valve [Re: tjmarcus1] #196403
01/17/09 10:24 PM
01/17/09 10:24 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
going from a 110 installed centerline to 106 will probably only net .015" additional clearance. recheck installed centerline and true rocker ratio. if the centerline is correctly installed and the rocker ratio isn't way off then the pistons will need work.
Re: Cam timing and piston to valve [Re: sixty9bee] #196404
01/17/09 11:06 PM
01/17/09 11:06 PM
before you go any further, check your intake valve clearance. if you have more clearance there you might be able to advance the cam and get enough for both. if not, you'll be flycustting pistons. most shelf ross pistons will not handle .700 lift safely.
Re: Cam timing and piston to valve #196405
01/17/09 11:28 PM
01/17/09 11:28 PM
louisiana
louisiana
the rocker ratio is 1.5 the lash was at 0 and the interference was minimal, as a matter of fact was not noticable until a dial indicator was used to check exact clearance. the intake was checked and has more than enough room through entire range. we could have 60-80 thou removed from the intake clearance and still be around 90 through the cycle.
Re: Cam timing and piston to valve [Re: sixty9bee] #196406
01/17/09 11:47 PM
01/17/09 11:47 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
with that much int. clearance, are you sure the cam is in right?
Re: Cam timing and piston to valve [Re: tjmarcus1] #196407
01/18/09 12:00 AM
01/18/09 12:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The cam does sound like its installed retarted more
than straight up
Re: Cam timing and piston to valve [Re: sixty9bee] #196408
01/18/09 12:03 AM
01/18/09 12:03 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
On the intake side a 1* at the crank is equal to around .003 to .004 lift at the lobe times rocker ratio.
Now if the exhaust lobe profile is similer you should see the same. It may be less since its Landing the valve.
But, requardless, your probably looking at around a extra .020 exhaust P/V clearence, with a 4* advance.
mike
Re: Cam timing and piston to valve [Re: Sport440] #196409
01/18/09 12:14 AM
01/18/09 12:14 AM
louisiana
louisiana
I know, it sounds like its in retarded. that was my first thought. checked and started over checked again. the valve relief is deeper on intake side. the only question on install is the cam is ground on 110 but my understanding is comp puts 4 degrees advance into the grind. if that is correct, it should probably not be installed at 110 right? by the way thanks for all the replies
Re: Cam timing and piston to valve [Re: sixty9bee] #196410
01/18/09 12:28 AM
01/18/09 12:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they grind in advance but you still start at 110
for 0 then advance it from there if you want advance
Re: Cam timing and piston to valve [Re: MR_P_BODY] #196411
01/18/09 01:43 AM
01/18/09 01:43 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Where your cam is installed now at a 110* ICL with a 110* LS you are neither advanced or retarded. Your at 0* Even if the cam had 4* advance ground into it.
mike
Re: Cam timing and piston to valve [Re: sixty9bee] #196412
01/18/09 12:26 PM
01/18/09 12:26 PM
NC
440Jim Offline
440Jim  Offline
NC
The best solution is the machine the exhaust valve reliefs in the pistons. But with a 110 LSA cam, I would not be afraid to install it with the intake lobe centerline at 104 ATC if needed, and you are willing to accept the trade offs.
Re: Cam timing and piston to valve [Re: sixty9bee] #196413
01/18/09 12:54 PM
01/18/09 12:54 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If comp cams says 106 on a 110 lobe center cam they install the dowel pin to try and have straight up be at 106 everything being equal. but the crank keyway , gear set and drilling the dowel in the pin is not an exact science With the exhaust being that
Re: Cam timing and piston to valve [Re: Dodgem] #196414
01/18/09 01:01 PM
01/18/09 01:01 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
With the exhaust being that close and the intake that loose I'd say something is way out of whack and that cam is severly retarded? The intake valve is usually the issue. Check and re check your marks rolling over but at this point I would suggest a true cam degree job
Just my thoughts have degreed lots and lots of cams
Lost some in my copy and past?? LOL???
Re: Cam timing and piston to valve [Re: Dodgem] #196415
01/18/09 01:08 PM
01/18/09 01:08 PM
louisiana
louisiana
probably should have also stated its split duration 277 intake 285 exhaust. degree'ed several but not an expert by any means. does the procedure change any for split duration? the only explanation i can come up with is that the valve pockets are deeper on the intake side (according to the paperwork on the pistons) and the longer exhaust duration is the culprit. is this logical or am i grasping straws? the pistons have no additional fly cutting only the ross factory reliefs
