Re: 727 and burnouts
[Re: Scott58]
#1962438
12/03/15 04:04 PM
12/03/15 04:04 PM
Posts: 721 Seminole County FL to Plymouth...
Barry70GTX
Just because "stuff" happens, it may be wise to buy a high quality billet front drum to basically eliminate the chance of a drum explosion. For about $700 you can get a front drum that won't blow up and will probably last a lifetime. Your right foot and trans tunnel may thank you. Expensive, but it sure gives me peace of mind running an 11 sec street car with an automatic valve body and drag radials... Or you could change out the valve body to one with LBA. Cheaper and easier to do.
NMCA NSS 67 Coronet
[Re: Barry70GTX]
#1962529
12/03/15 05:24 PM
12/03/15 05:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put in a super sprag... they are suppose to be bullet proof... if it doesnt blow/roll over the sprag then you wont hurt the drum
[Re: Scott58]
#1962853
12/04/15 01:44 AM
12/04/15 01:44 AM
MR_P_BODY
Is there an automatic shifting valve body that has LBA in drive?
The sprag is only engaged in low/1st gear.. so thats the only time you need to worry about it EDIT the stock VB has LBA.... on your question... no
[Re: MR_P_BODY]
#1962864
12/04/15 02:08 AM
12/04/15 02:08 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Put in a super sprag... they are suppose to be bullet proof... if it doesnt blow/roll over the sprag then you wont hurt the drum Do you know how much they cost as I would like to put one in mine the next time I pull my trans ? Ron
[Re: 383man]
#1962870
12/04/15 02:18 AM
12/04/15 02:18 AM
MR_P_BODY
Put in a super sprag... they are suppose to be bullet proof... if it doesnt blow/roll over the sprag then you wont hurt the drum Do you know how much they cost as I would like to put one in mine the next time I pull my trans ? Ron They are like a $150.... I think
[Re: MR_P_BODY]
#1962882
12/04/15 02:26 AM
12/04/15 02:26 AM
383man
Balt. Md
Put in a super sprag... they are suppose to be bullet proof... if it doesnt blow/roll over the sprag then you wont hurt the drum Do you know how much they cost as I would like to put one in mine the next time I pull my trans ? Ron They are like a $150.... I think Thank you. Ron
[Re: Tempest]
#1962984
12/04/15 10:58 AM
12/04/15 10:58 AM
Posts: 836 Up a holler, down a crick
booger
I put a Coan super sprag and LBA valve body in my transmission expecting to drive on the street.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
[Re: Tempest]
#1963028
12/04/15 12:29 PM
12/04/15 12:29 PM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
I understand do not pedal in first great and most people start out in second gear. I like to start out in first gear (never free wheel it) I Just shift into second gear and shift 3rd gear. No brakes or line lock. My burnouts are for distance I guess, alway increasing throttle. My car is mostly a street car, track maybe once a year. Trans is build for the street with a lot of goodies talked about above. 440 702 hp and 650 torque at the flywheel. 727 MVB 9 inch tight convertor. New motor has not been to the track yet. So is this way ok for the trans? If I do a brake stand burnout always 2 to 3. Great info guys.
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
