1969 Door Hing bolts #1959248
11/28/15 02:39 PM
11/28/15 02:39 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
In 69 - for the door hinge bolts - was there a pattern for what got the wide washers vs the small ones?
68 Satellite Wagon and a few other ones
Re: 1969 Door Hing bolts [Re: mro] #1959726
11/29/15 03:01 PM
11/29/15 03:01 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Following information is correct for '69 A body, but I think B body is the same:
3/4" washers are the door side of the hinges. (Maker's mark "23", 5 pieces each side.)
1-1/8" washers are the cowl side of the hinges. (Maker's Mark "F", 6 pieces each side.)
In many cases, especially on body sheet metal, since the washers are conical, a faint impression of the washer diameter can be seen on the parts with close examination.
