Re: Carb tuners
[Re: DaveRS23]
#1963389
12/04/15 10:14 PM
12/04/15 10:14 PM
Posts: 7,506 Az
Crizila
Az
Pulled the carb apart today. the 4 emulsion holes are the same for both pri. and sec. sides. #1 (top hole) is .029",#2 hole is plugged, #3 hole = .026", and #4 ( bottom hole) is .091". All holes are below the recommended float level. Since they are all below the fuel level in the bowls, I don't think making the top hole smaller is going in the right direction to cure my off idle lean condition I'm looking at opening up the second ( plugged hole) to some size ??? Your thoughts? Remember, this is a blow through carb.
Fastest 300
Re: Carb tuners
[Re: Crizila]
#1963719
12/05/15 01:16 PM
12/05/15 01:16 PM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
This is just a guess and is not based on any experience, but why not try opening up the second hole since it is below the fuel level and see how the engine likes it. You can always plug it back if the engine doesn't respond well. And you may consider experimenting with the top hole as well once you get a sense of how the second hole affects things. As long as you do one thing at a time and keep track of what you do, you can always put it back the way it was.
Master, again and still
Re: Carb tuners
[Re: DaveRS23]
#1963780
12/05/15 02:51 PM
12/05/15 02:51 PM
Posts: 7,506 Az
Crizila
Az
This is just a guess and is not based on any experience, but why not try opening up the second hole since it is below the fuel level and see how the engine likes it. You can always plug it back if the engine doesn't respond well. And you may consider experimenting with the top hole as well once you get a sense of how the second hole affects things. As long as you do one thing at a time and keep track of what you do, you can always put it back the way it was. Think that's what I'm gonna try.
Fastest 300
Re: Carb tuners
[Re: DaveRS23]
#1963850
12/05/15 05:15 PM
12/05/15 05:15 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I'm also thinking that back pressure is diluting the combustion chamber causing it to go lean,,,,,,,,,,,
Re: Carb tuners
[Re: hemi-itis]
#1964316
12/06/15 01:04 PM
12/06/15 01:04 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I'm also thinking that back pressure is diluting the combustion chamber causing it to go lean,,,,,,,,,,, If there were enough back pressure just off idle to significantly impact the fuel mixture, what would be happening at WOT?
Re: Carb tuners
[Re: DaveRS23]
#1964352
12/06/15 02:06 PM
12/06/15 02:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm also thinking that back pressure is diluting the combustion chamber causing it to go lean,,,,,,,,,,, If there were enough back pressure just off idle to significantly impact the fuel mixture, what would be happening at WOT? IF it had that much back pressure it would do 1 of 2 things at higher rpm.. 1.. it would blow the exhaust off the car(at any one of the joints).. or 2.. it wouldnt make the rpm... its making some rpm (I dont know how many rpm he is turning) so at idle/just off idle he shouldnt see any issues at those rpms... he HAS to put a gauge on it to see what his back pressure TRULY IS and work from there.. when I was testing all sorts of exhaust I did see a system blow the pipe off during a test.. needless to say we didnt use that system.... the nice little inward roll on the exhaust tip(on the chrome tips) was a 3hp loss with just that inward roll on the tip(thats back pressure due to flow loss).. most people would never think that would be a issue EDIT to check the idea of the mixture going lean.. one way to test that.. pull the exhaust off(open it) and run it with a A/F meter... On my Rampage I went with elec dumps just so I didnt pull the exhaust but yet reduce the back pressure
Re: Carb tuners
[Re: MR_P_BODY]
#1964371
12/06/15 03:02 PM
12/06/15 03:02 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I'm also thinking that back pressure is diluting the combustion chamber causing it to go lean,,,,,,,,,,, If there were enough back pressure just off idle to significantly impact the fuel mixture, what would be happening at WOT? IF it had that much back pressure it would do 1 of 2 things at higher rpm.. 1.. it would blow the exhaust off the car(at any one of the joints).. or 2.. it wouldnt make the rpm... its making some rpm (I dont know how many rpm he is turning) so at idle/just off idle he shouldnt see any issues at those rpms... he HAS to put a gauge on it to see what his back pressure TRULY IS and work from there.. when I was testing all sorts of exhaust I did see a system blow the pipe off during a test.. needless to say we didnt use that system.... the nice little inward roll on the exhaust tip(on the chrome tips) was a 3hp loss with just that inward roll on the tip(thats back pressure due to flow loss).. most people would never think that would be a issue EDIT to check the idea of the mixture going lean.. one way to test that.. pull the exhaust off(open it) and run it with a A/F meter... On my Rampage I went with elec dumps just so I didnt pull the exhaust but yet reduce the back pressure My question was really meant to be rhetorical. And I also went with electric cut-outs because getting a relatively quiet exhaust to flow my 500" engine kept getting more and more complicated and more and more expensive. And frankly, the only way to truly know what combo was going to work, was to install it and test at the track back to back. But that would require buying a lot of pipes and mufflers besides being a bunch of work. The Doug's cut-outs are sure-fire at the track and are a lot of fun at shows and cruises. Plus, I get to listen to the radio and/or talk to my passenger while driving down the road.
Re: Carb tuners
[Re: hemi-itis]
#1964374
12/06/15 03:10 PM
12/06/15 03:10 PM
Posts: 304 Florida
Mark Whitener
I would suggest swapping the top and second emulsion holes, plug the top, .029 in the 2nd. And are you sure about the .091 bottom? I would try plugging it, way too large.
Mark Whitener [url=www.racingfuelsystems.com[/url]
Re: Carb tuners
[Re: Mark Whitener]
#1964480
12/06/15 06:22 PM
12/06/15 06:22 PM
Posts: 7,506 Az
Crizila
Az
I would suggest swapping the top and second emulsion holes, plug the top, .029 in the 2nd. And are you sure about the .091 bottom? I would try plugging it, way too large. Ok, First, the run I posted is with open headers ( no back pressure on the exhaust side). On the carb side, the dump valve ( anti-surge valve ) remains open (Dumps air to atmosphere )until the manifold goes in to pressure - so my lean condition ( about 1200 to 2000 rpm )occurs while the manifold is still under vacuum. Even doing a burnout ( see posted run ) the engine is still under vacuum. The minute I floor it, vacuum drops to 0, dump valve closes, and manifold goes in to pressure - and lean condition goes away. Yes, I am sure about the emulsion sizes I previously posted. So, I went ahead and drilled out the 2nd emulsion hole ( previously plugged ) to .026". Four holes ( top to bottom ) are now .029, .026, .026, and .091. Just ran the car that way. Virtually no change. Lean spot is still there. A/F reading at idle might have gone a little richer ( 12.0:1 to 11.5:1 ). Still open for other suggestions. FYI, shifting at 7K. Will probably go back to how it was and try something else.
Fastest 300
Re: Carb tuners
[Re: hemi-itis]
#1966213
12/09/15 12:00 PM
12/09/15 12:00 PM
Posts: 7,506 Az
Crizila
Az
Talked with Patrick over at ProSystems yesterday. They are my original carb builder. He wants me to pull out the primary side PV and plug it (sec side is plugged) and jet up to the sec side jet size. I will give this a try next.
Fastest 300
