Hemi rocker arm shaft bolts? #1956941
11/24/15 04:01 AM
11/24/15 04:01 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi everybody. I know Hemi rocker are shaft bolts are 3/16NC but how long are they? Trying to put an order together for ARP and I don't know the length.
Thanks, Troy
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Hemi rocker arm shaft bolts? [Re: Troy] #1956951
11/24/15 05:23 AM
11/24/15 05:23 AM
Australia
Teamx Offline
Teamx  Offline
Australia
Here you go!
Re: Hemi rocker arm shaft bolts? [Re: Troy] #1957023
11/24/15 12:33 PM
11/24/15 12:33 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I assume 3/16" is a typo
2011 Drag Pak Challenger
Re: Hemi rocker arm shaft bolts? [Re: rickseeman] #1957185
11/24/15 05:26 PM
11/24/15 05:26 PM
iagree whistling 3/8x16 is what I remember shruggy
Re: Hemi rocker arm shaft bolts? [Re: Troy] #1957390
11/24/15 11:13 PM
11/24/15 11:13 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Oops, my bad. Yes, 3/8. Thanks everybody.
Re: Hemi rocker arm shaft bolts? [Re: Troy] #1957577
11/25/15 10:48 AM
11/25/15 10:48 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Why ARP bolts for the rocker shaft to stand bolts? All they do is positively locate the shafts in the stands, keep them from sliding, and turning. The only time i think they would see an actual load is if a rocker seized and tried to twist the shaft. If I'm wrong, somebody set me straight on this.
Re: Hemi rocker arm shaft bolts? [Re: 73DAD] #1957616
11/25/15 12:11 PM
11/25/15 12:11 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Your correct,only need grade 5 or 8 bolts,the ARP stuff is for the the "wow".If the rocker seizes and wants to turn the shaft with 5 bolts holding it then there is a bigger problem. whistling
