70 Duster LCA pivot shaft
#1955406
11/21/15 04:18 PM
11/21/15 04:18 PM
Posts: 1,487 STL
cdstl
STL
I need a different pivot for the LCA since the one on there is bent. Are the shafts different lengths between A body and B body?
Also, I plan heading the big Mopar junkyard near STL tomorrow and will be looking for tabbed LCAs and maybe even a sway bar setup. I'm familiar with the tab positions on the '72 and earlier LCAs.
What I need to know is how long is an A body LCA. I don't have mine at the house and won't get them before tomorrow. Clay says that he has some laying around and I don't want to grab the wrong ones. I know A body LCAs are longer than B or E.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 70 Duster LCA pivot shaft
[Re: cdstl]
#1955432
11/21/15 04:52 PM
11/21/15 04:52 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
I need a different pivot for the LCA since the one on there is bent. Are the shafts different lengths between A body and B body? Yes. VL stamping are A body. PD & RW stamping are B & E body. A body on the left. Early B Body in the middle. B & E Body, on the right.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Kern Dog]
#1955493
11/21/15 08:01 PM
11/21/15 08:01 PM
Posts: 1,487 STL
cdstl
STL
B body shafts are different. They have a "step" in them where the A body shafts are smooth. A body LCAs are flat along the middle of the bottom edge. B body LCAs have a curve along the bottom edge. Well I figured as much, but it doesn't hurt to ask. I knew the A body LCA was longer but not about the "flat" spot. I'll look at my Cuda before we go. Thanks
[Re: cdstl]
#1956153
11/22/15 11:00 PM
11/22/15 11:00 PM
Posts: 1,487 STL
cdstl
STL
Did well today. Picked up a complete sway bar setup with the tabbed LCAs, VL stamped on them, and various other items that we needed.
