color sanding and buffing #1953641
11/18/15 12:53 PM
11/18/15 12:53 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Suggestions for paper grit and compound to use. Factory base coat / clear coat paint. Don't want to get in to the base coat, but need to remove some minor dirt in the clear. Thanks, John
Fastest 300
Re: color sanding and buffing [Re: Crizila] #1953762
11/18/15 04:16 PM
11/18/15 04:16 PM
Far Northeast.
mymcodebee Offline
mymcodebee  Offline
Far Northeast.
I would not go less than 1500. 2000 and 3000 will make buffing much easier. I use the 3M Hook It system on a palm sander. Then buff with Presta buffing and finishing compound. I like Presta as it cleans easily with water. Its not cheap to get the material above. The pads, sanding disks and compound are quite expensive but it is one of the better ways to handle it. Good Luck.
