Re: Small block copper oil pump gasket
[Re: dizuster]
#1953410
11/18/15 12:59 AM
11/18/15 12:59 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I made a copper one so far so good
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: rickraw]
#1954168
11/19/15 07:12 AM
11/19/15 07:12 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I just used some anarobic sealer. Ding-ding, winner.
"I think its got a hemi"
[Re: Hunted Duck]
#1954338
11/19/15 04:02 PM
11/19/15 04:02 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I pretty much always use no gasket, if they are not flat enough to seal up you got an issue you need to fix. The factory never used them. One less gasket or sealant to blow out into the pan. If it leaks it would be very tiny and not worth any fuss. One time I had one where it looked like they had an extra dull cutter machine it and I used a very thin coat of right stuff, I think it would have probably been fine with out.
