Re: What is this 5 speed out of?
[Re: 135sohc]
#1953510
11/18/15 04:04 AM
11/18/15 04:04 AM
Posts: 550 SW Missouri
moparmandjh
SW Missouri
Thanks, any idea what years? So it wouldn't stand up to a 360?
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
[Re: moparmandjh]
#1953744
11/18/15 03:45 PM
11/18/15 03:45 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
NV3500 Specifications and gear ratios
•Single shift rail •Distance between the centerline of the mainshaft and the countershaft is 85 mm •Fully synchronized forward and reverse gears •Two-piece aluminum housing with no access plates •Shift tower mounted shift leaver •Dodge order code DDC •Rated for 310 ft-lb of torque (in 1994) •Weight: 110 pounds, dry
1st 2nd 3rd 4th 5th R
Dodge Ram 1500, Dodge Dakota** 4.01 2.32 1.40 1.00 0.73 3.55
**As of 1994, as per Chrysler tech and press materials. May have been different in later years.
