Re: Please help identify these P/S pumps!
[Re: Kern Dog]
#1952708
11/17/15 12:52 AM
11/17/15 12:52 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Both of the pumps in the top pic are Saginaw, they changed to the larger housing on the later models. If you get a reman one from the parts store you will most likely get the bigger housing. I take the pump assembly out of the later housing and put it in the older small housing for the correct look.
The only Carbs I care about are under the hood!
[Re: gold66cuda]
#1952795
11/17/15 04:05 AM
11/17/15 04:05 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Hey Greg, careful with the first one you showed, they have been known to blow their top if you remember! I'll bet it is okay with the flaky black paint and layer of grime! The chrome ones are trouble!
