915 or 906 Heads
#195251
01/16/09 04:37 PM
01/16/09 04:37 PM
Posts: 1,534 Florida
CHRGR69
Which are better? And how do you tell the difference with them still on the block?
Grandma always said I had "hands of gold"!
Re: 915 or 906 Heads
[Re: CHRGR69]
#195254
01/16/09 09:57 PM
01/16/09 09:57 PM
RapidRobert
906's cost $60-100 a pair. 915's several hundred a pair & are fairly hard to come by as it was (1)year only(1967) whereas 906's ~ 3 years. If you want a quench motor(smart move) & dont want to step up to one of the alum heads then go with a 915 with the right piston/head gasket.
[Re: RapidRobert]
#195257
01/16/09 10:49 PM
01/16/09 10:49 PM
Posts: 777 Washougal,Wa
Dodge
Washougal,Wa
Ok, I have to ask. What is quench and can you put 915s on a smogger engine to get the compression up, or are you changing the quench area? If I put 915s on a 10 to 1 compression motor, won't it ping from to high of compression?
Stand behind your word
[Re: 1_WILD_RT]
#195259
01/17/09 12:01 AM
01/17/09 12:01 AM
Posts: 908 North Chicagoland
newbee69
North Chicagoland
What is quench
Read this..
http://racingsecrets.com/article_racing-10.html
I was not too sure of this either, but the guys here on the forum explained it to me and this article seems like it hits it right on the head. Not to hijack, but wouldnt all BB and RB's be considered non-quench motors? What would be the advantage? Lower CR? Emission control?
[Re: 1_WILD_RT]
#195261
01/17/09 10:48 AM
01/17/09 10:48 AM
Posts: 1,047 Arizona
68CoronetRT
Arizona
But if your gonna pay $250-300+ for a set of core heads..Then 400-500+ to rebuilt them...Your well along in buying a set of Stealth heads..
My thinking exactly. You'll get the bigger valves, better flow and quench not to mention less weight and the ability to run about 1 point higher compression ratio.
[Re: CHRGR69]
#195262
01/17/09 10:59 AM
01/17/09 10:59 AM
Posts: 417 jamestown, ny
71scamp440
Hinged
Hinged
jamestown, ny
915's here got the pair fully dressed for $500.
71 scamp
big block with 915 heads
727 trans
