oil pressure
#1941872
10/30/15 11:37 PM
10/30/15 11:37 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I have a 2004 Dakota with a 3.7 V6. Today out of the blue while idling at a stop sign I heard the ding sound that you hear when your check gauges light comes on. I looked at my gauges and the oil pressure gauge showed no pressure. I tapped the gas and it went back to normal.It stayed normal for a while at some red lights then it done it again. I stopped and checked the oil and it was full. I just changed the oil last week end. If there was a serious problem with the motor why would the pressure drop to zero some times when I stop and not do it every time. Could that mean it could be the factory gauge? Has anybody else had this issue? Thanks....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: oil pressure
[Re: stumpy]
#1945259
11/04/15 09:50 PM
11/04/15 09:50 PM
D-50
North, Alabama
What brand filter did you use? Fram and 10w30 oil........ It has acted fine the last couple of days.
Re: oil pressure
[Re: rickstershemi]
#1949096
11/10/15 11:20 PM
11/10/15 11:20 PM
D-50
North, Alabama
How much is involved or how hard is it to swap to a 5.7 Hemi. Would I have to swap transmissions also?
