4-2-1 merge collectors #1946955
11/07/15 02:53 PM
11/07/15 02:53 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone here ever try them? a few years back i tried a custom 4 into 1 stainless merge collector and seen nothing on slip. do ya think these 4-2-1 collectors are just another way to get your money? i see them used in nascar.
Re: 4-2-1 merge collectors [Re: mopar dave] #1947099
11/07/15 07:54 PM
11/07/15 07:54 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
There was a discussion on Classracer about the merge collectors and cam timing changes needed to make them work. I think there was some discussion on the Tri-Y headers as well. It might be worth a read if you haven't read it already.
http://classracer.com/classforum/showthread.php?t=59745
Floyd Lippencott IV
Re: 4-2-1 merge collectors [Re: mopar dave] #1947114
11/07/15 08:22 PM
11/07/15 08:22 PM
AndyF Offline
AndyF  Offline
They certainly do work but they might not work for you. One reason is that you might not be able to get a set of headers built for your car that both fit and work. The primary pipes need to be really short to use the 421 collector and that can be hard to package into a car.
Another point is that the guys who pick up power with the merge headers are typically doing something different with the head and cam. One example is using the header design to pull harder on the exhaust. Once you do that you can put a smaller exhaust valve in the head which then lets you put a larger intake valve. This is the trick that NASCAR guys did a few years back and it is the trick that some pro drag race teams use. But it is super expensive for the average guy to try and do these tricks.
Re: 4-2-1 merge collectors [Re: AndyF] #1947124
11/07/15 08:44 PM
11/07/15 08:44 PM
Mt Morris Michigan
Mt Morris Michigan
OK. Sounds like that's not for me. I'll read the LINC above.
Re: 4-2-1 merge collectors [Re: mopar dave] #1947211
11/07/15 10:18 PM
11/07/15 10:18 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I have flowmaster 4/2/1 collectors on both sets of headers I made. First set is on the sm block in the demon and the other set is on the big block in the lebaron. Both cars run pretty well for what they are.
Re: 4-2-1 merge collectors [Re: qwkmopardan] #1947244
11/07/15 11:18 PM
11/07/15 11:18 PM
Mt Morris Michigan
Mt Morris Michigan
I understand those are good for some mid torque.
Re: 4-2-1 merge collectors [Re: mr_340] #1947343
11/08/15 01:57 AM
11/08/15 01:57 AM
Mt Morris Michigan
Mt Morris Michigan
thanks for the linc. I will call elston headers when I get a chance. he should be able to point me in right direction being he builds headers for nascar as well as nhra and others. he also uses Burns stainless for collectors. learned a lot from your linc
Re: 4-2-1 merge collectors [Re: mopar dave] #1947367
11/08/15 03:17 AM
11/08/15 03:17 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
You mean these ? lol
I bought them , welded on the evac tubes and had them coated.......only to decide that I really didn't need to enhance torque.
I went with a straight 3 1/2 " collector.
1 7/8ths primaries and they look like they'll lay pretty well against the floor.
I'll let them go cheap if anyone wants to try them out.
Re: 4-2-1 merge collectors [Re: tubtar] #1947484
11/08/15 01:21 PM
11/08/15 01:21 PM
Mt Morris Michigan
Mt Morris Michigan
yes, exactly. from what i'v read they can be hard to tune. they need to be tuned to the combo and mostly the cam timing or duration. i still may be interested. pm me the lenghts and all tubing sizes with a price. i'm heading north now so i'll get back later. whos are they?
Re: 4-2-1 merge collectors [Re: mopar dave] #1947575
11/08/15 04:02 PM
11/08/15 04:02 PM
AndyF Offline
AndyF  Offline
Those will work if you can cut your primaries down to about 20 inches. You have to get the primaries really short for that combo to work properly and most shelf headers just can't be cut short enough. There isn't anything wrong with the idea, it usually just doesn't fit in a Mopar very well.
Re: 4-2-1 merge collectors [Re: AndyF] #1948103
11/09/15 03:38 PM
11/09/15 03:38 PM
Mt Morris Michigan
Mt Morris Michigan
yes, i'v seen that before. i dont know the length of my primarys, but i know their longer than 20 inches. thanks Andy
Re: 4-2-1 merge collectors [Re: mopar dave] #1948163
11/09/15 05:38 PM
11/09/15 05:38 PM
AndyF Offline
AndyF  Offline
Check out this picture of NASCAR headers. Good luck getting that setup to fit in a Mopar with the torsion bars, steering box and steering linkage all in the way!
Re: 4-2-1 merge collectors [Re: AndyF] #1948205
11/09/15 06:53 PM
11/09/15 06:53 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
And they have them paired correctly. Very important for merge collectors to work.
Re: 4-2-1 merge collectors [Re: qwkmopardan] #1948423
11/09/15 11:34 PM
11/09/15 11:34 PM
Mt Morris Michigan
Mt Morris Michigan
What do you mean by paired?
Re: 4-2-1 merge collectors [Re: mopar dave] #1948432
11/09/15 11:50 PM
11/09/15 11:50 PM
AndyF Offline
AndyF  Offline
You want to space the exhaust pulses out in the collector. So on a Mopar with 5-7 that fire next to each other you would put those cylinders into different sides of the collector. If you use a 4-7 swap cam then you might need to change the way a 4-2-1 header is routed.
The Schoenfeld header page shows some of this stuff. They sell 4-2-1 headers for race engines and they'll tell you which ones work with which firing orders.
Re: 4-2-1 merge collectors [Re: AndyF] #1948498
11/10/15 01:10 AM
11/10/15 01:10 AM
Mt Morris Michigan
Mt Morris Michigan
I'll check that out. Thank you.
Re: 4-2-1 merge collectors [Re: mopar dave] #1948519
11/10/15 01:37 AM
11/10/15 01:37 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Hey Andy:
I have a manual from "Headers by Ed". He says that the primaries should lay out in rotation of firing order. Clockwise or counterclockwise isn't critical. But it should go 1-3-5-7 and 8-4-6-2. Standard cam firing order. That's not how the drivers side header is set up. But I have seen the pattern on the Chevy motor before on other headers. Is it just ease of fitment, or another theory on what works best?
[image][/image]
Re: 4-2-1 merge collectors [Re: mopar dave] #1948531
11/10/15 01:59 AM
11/10/15 01:59 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Do we know the firing order of the NASCAR Chevy engine? It might have the LS1 firing order (1-8-7-2-6-5-4-3)
Floyd Lippencott IV
Re: 4-2-1 merge collectors [Re: AndyF] #1948541
11/10/15 02:24 AM
11/10/15 02:24 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
20 inches for the primaries ?
Is that to maximize h.p. when using them ?
To my way of thinking , there is a balancing act when you change anything in header design.
A longer primary will cost you peak h.p. , but typically will enhance torque.
I don't know that these will have the same effect as a merge collector , where a smaller primary can be used due to scavenging being enhanced.
Given that they have a 3" collector to finish , I don't know that they had high r.p.m. in mind when they designed them.
But I think you could go longer than 20 " and not lose much.
