Travel limiters #1943373
11/01/15 11:23 PM
11/01/15 11:23 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Can you guys post pics of your front end travel limiters? On stock suspension car please.
Re: Travel limiters [Re: RV2] #1943414
11/02/15 12:16 AM
11/02/15 12:16 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Here are mine............
Re: Travel limiters [Re: RV2] #1943416
11/02/15 12:20 AM
11/02/15 12:20 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Chain from the frame rail to the lower control arm. Attached with a small clevis, it's cheap and adjustable!
Re: Travel limiters [Re: RV2] #1943419
11/02/15 12:25 AM
11/02/15 12:25 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
On a related note, What is the reasoning behind limiting the travel of the front end? Also, how do you know how much to limit it?
Re: Travel limiters [Re: RV2] #1943423
11/02/15 12:31 AM
11/02/15 12:31 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
You can set the travel further than stock for more front end rotation and bigger hit on the rear tires, or shorter to help control wheel stands.
[image][/image]
Re: Travel limiters [Re: RV2] #1943451
11/02/15 01:51 AM
11/02/15 01:51 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I will probably get blasted..........but a travel limiter is a crutch for a poor performing shock, if your reason for installing it is based on what your car does on the starting line.
I run a limiter, but it's primary purpose is the set the ride height of the front of the car going down the track. I use the shocks to control the rate of rise........as that is their purpose after all......LOL!!!
Re: Travel limiters [Re: RV2] #1943566
11/02/15 10:46 AM
11/02/15 10:46 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Monte is correct, I've only messed with limiters on cars that had good shocks on the wish list.
Re: Travel limiters [Re: RV2] #1944019
11/02/15 10:24 PM
11/02/15 10:24 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
My car rises and stays up throughout the run, the tires camber out and it gets real scary on the top end, the front end does not come down till I let off.
At rest.
Re: Travel limiters [Re: RV2] #1944020
11/02/15 10:27 PM
11/02/15 10:27 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
At launch
Re: Travel limiters [Re: RV2] #1944024
11/02/15 10:29 PM
11/02/15 10:29 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I do not have good shocks on it. Sorry Monte
Comps on the front set loose and Ranchos on the rear set at #3
Re: Travel limiters [Re: RV2] #1944148
11/03/15 12:19 AM
11/03/15 12:19 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
is it a street car? if not have it aligned with the front suspension at droop, like it would be going down the track.
Re: Travel limiters [Re: upnover] #1944341
11/03/15 11:28 AM
11/03/15 11:28 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
bingo! and if it is a street car just jack the front up (k frame up) about half of your travel and set alignment to find a happy medium.
Re: Travel limiters [Re: RV2] #1944514
11/03/15 06:20 PM
11/03/15 06:20 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
It's a race only situation, I thought about jacking it up and putting some negative camber in it.
Re: Travel limiters [Re: RV2] #1945136
11/04/15 05:25 PM
11/04/15 05:25 PM
gregsdart Offline
gregsdart  Offline
If you still decide to run limiters use some form of soft stop similar to factory bumpers so when they hit it doesn't shock the chassis
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Travel limiters [Re: RV2] #1945985
11/05/15 10:39 PM
11/05/15 10:39 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
If you decide to just align it for the down track lift, it might be a good idea to roll it forward on the jack a few feet before you start wrenching. Limiters sound like the best fix, next to shocks of course. Tires are so good now you could probably just tie the front completely down, and it would still hook.
Re: Travel limiters [Re: RV2] #1946014
11/05/15 11:07 PM
11/05/15 11:07 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I decided to replace the front shocks(comp eng) since they were hand me downs anyway.
I ordered some QA1 double adjustables
Early Christmas present to myself!
Re: Travel limiters [Re: RV2] #1946158
11/06/15 08:39 AM
11/06/15 08:39 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Ohhh yeah, thank ya jebus lol
Re: Travel limiters [Re: RV2] #1946213
11/06/15 11:34 AM
11/06/15 11:34 AM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Lol
You can help me dial it in fruity!
