727 transmission cooling line size? #194348
01/15/09 12:42 PM
01/15/09 12:42 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
What size are the lines and fittings for a 727 transmission for a BB?
Re: 727 transmission cooling line size? [Re: 74RR] #194349
01/15/09 12:51 PM
01/15/09 12:51 PM
organ
maximum entropy Offline
organ
the lines are 5/16, the trans fittings are 1/8th pipe to 5/16 flare, and the radiator fittings are either the same as the trans fittings, or sometimes 1/4 pipe to 5/16 flare. unless of course someone has been mucking about.
