Re: which hemi rockers have the most accurate ratios?
[Re: ogopogo]
#1941760
10/30/15 07:05 PM
10/30/15 07:05 PM
Posts: 4,210 New York
polyspheric
New York
Doesn't RAS have a blueprint service for this?
Boffin Emeritus
[Re: ogopogo]
#1941891
10/31/15 12:02 AM
10/31/15 12:02 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Spent the money for the RAS and still had to buy some stageV's, there is a reason they are the best, also consider dechellies shafts, they had the nicest fit and finish that I have seen on any of them. Tim
Mine were better after the RAS blueprint, stock widepads but they were only 1.36-1.4 ratio at best, the stageVs are 1.51~1.52 consistently on the ones that I used. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1941898
10/31/15 12:07 AM
10/31/15 12:07 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
stage Vs. Or get a set of widepad stock rockers and send em to be rebuilt to rocker arm unlimited. they do great work and will blueprint ratios. stock non roller rockers work great. http://www.rockerarms.com/
[Re: ogopogo]
#1941933
10/31/15 01:06 AM
10/31/15 01:06 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
If you read the Mancini add, the price listed does not include the shafts , springs or the stands, just the rockers and adjusters. So when you purchase the rest I bet you are close to Stage V cost. Just spend the money on stage V and be happy for the rest of your Hemi days
[Re: ogopogo]
#1942028
10/31/15 10:43 AM
10/31/15 10:43 AM
Posts: 12,252 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Has anyone checked the accuracy of the DLI rockers? I have a set on one engine and have another set to go on the next project. They are certainly durable enough, but I had never thought to check their ratios until lately with all these posts.
Master, again and still
[Re: DaveRS23]
#1942258
10/31/15 03:26 PM
10/31/15 03:26 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
You should really check every Hemiroid rocker ratio at the valves on any rocker arm your going to use I use a set of checking springs and on one side of the motor and swap the rocker assemblys only, I set the lash at zero and carefully align the dial indictor stems to match the angles of the valve stems
[Re: SSDAcuda]
#1942295
10/31/15 04:41 PM
10/31/15 04:41 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
[quote=SSDAcuda]Talking best?? When $ isn't in the equation… Ray Barton shaft rockers are the best! Never ran the cam f/x but their lifters and customer service leaves a lot to be desired. And I ran Jesel's before and am a big supporter of ALL there products, and YES, RBRE rockers ARE THE BEST!! May cost a little more, but your buying them only once! [/quote Sorry to hear you had a bad experience with Cam Fx parts.......The rocker arms that Ray Barton sells for his hemi's are actually made by t&d.. And without a doubt there is absolutely nothing wrong with T&d rocker arms. I have been running t&D machine parts for years myself also. It is just nice to have a choice.and to see a new manufactur bring a really nice bulletproof piece to the market for our old Mopar's.....all cam fx rocker body's have a LIFETIME WARRANTY for breakage....
[Re: ogopogo]
#1943496
11/02/15 06:48 AM
11/02/15 06:48 AM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Maybe I should have payed closer attention to my stock rockers.
Chris from New Jersey
[Re: fig426]
#1943537
11/02/15 11:05 AM
11/02/15 11:05 AM
Posts: 12,415 Taxes & Virus's R-US, NY
Dragula
Maybe I should have payed closer attention to my stock rockers. Been there, done that....More than once, actually. Its usually not the rockers that cause that. Generally there was another cause. Too much rpm for the springs your running is the main reason we see, or lack of a rev limiter. Or what have seen more recently, the groove between the valve & the lock gets wiped out and drops a valve. Bad locks...But not usually the rockers fault.
[Re: fig426]
#1943570
11/02/15 11:54 AM
11/02/15 11:54 AM
domingo
EL Master
EL Master
Lima, Peru
Maybe I should have payed closer attention to my stock rockers. Dont blame the stock rockers!!! Look for your problems someplace else!!!
[Re: ogopogo]
#1943585
11/02/15 12:19 PM
11/02/15 12:19 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
It's mostly true that when you have a valve train issue it is usually caused by something other than a rocker arm.We found that the rockers for hemis offered on ebay and other site that are made in Canada or off shore to be junk.The rollers and pins are not hardened,the ratios are all over the place,adjusters are junk as is the thread pitch in the rocker. If cost is no concern then The Jesel and T&D(Barton)and StageV are the best option.We have never had an issue with Indy rockers and run them on most all our hemis including Don's blower car,zero failures.The stock rockers are strong but need to be corrected for all out race application,for the street/strip they work fine.Landy,(if you can find them) have had pin issues and Norris(same) have pin and clearence issues,We have no experience with any other brands.Stay away for the Canada(ebay) junk.
