Page 6 of 12 1 2 4 5 6 7 8 11 12
Re: 420cid build with a new Ritter Aluminum Block [Re: Dragula] #1941431
10/30/15 12:39 AM
10/30/15 12:39 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Originally Posted By Dragula
Two stupid questions.....What is the difference between the XR1 and the XR2 aluminum blocks?
And what heads are you guys typically running on these?
XR2=P7 heads
XR1=W7,8,9 heads
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 420cid build with a new Ritter Aluminum Block [Re: Dragula] #1941490
10/30/15 02:13 AM
10/30/15 02:13 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
XR1 takes the wedge style LA series head
XR2 takes the Dodge P7 head. These blocks were designed primarily to run the P7 heads (As Kent as a very large stock pile of them)
Alan Jones
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1941648
10/30/15 02:17 PM
10/30/15 02:17 PM
Pennsylvania
P
P7 Engineering Offline
P
Pennsylvania
Aluminum block with sleeves is $4800 is my understanding.......
My 1974 2WD shortbed Chevy Truck build thread:
http://67-72chevytrucks.com/vboard/showthread.php?t=525098
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1941688
10/30/15 04:08 PM
10/30/15 04:08 PM
Waterloo Iowa
8
80mirada Offline
80mirada  Offline
Waterloo Iowa
That would be an excellent price......if they can work out the bugs that will be am excellent deal
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1947836
11/09/15 12:31 AM
11/09/15 12:31 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
How's it coming Mike!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1947891
11/09/15 02:35 AM
11/09/15 02:35 AM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
This weekend was spent moving one of my neighbors.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1948233
11/09/15 07:35 PM
11/09/15 07:35 PM
Kansas, Topeka
69 lawndart Offline OP
Kansas, Topeka
Short block is assembled, At this point in time we are flowing the heads through the intake and throttle body, and with the headers. When that is done everything is ready to finish the long block. The next step is to run it on the test stand. Have a few small things to finish on the run stand. I will post the results and a video of start up and it running.
Thanks for all of the input and interest.
Mike
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1948252
11/09/15 08:11 PM
11/09/15 08:11 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
So what's a guy use for a cam in an XR2 P7?
Re: 420cid build with a new Ritter Aluminum Block [Re: SpareParts] #1948422
11/09/15 11:33 PM
11/09/15 11:33 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
You use a r5 cam and have the snout modified by lsm.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: 420cid build with a new Ritter Aluminum Block [Re: MoparBilly] #1956196
11/23/15 12:00 AM
11/23/15 12:00 AM
Kansas, Topeka
Kansas, Topeka
Update, it is on the run stand waiting on the right length pushrods and a few fittings and I hope to have it running.
Will keep you posted.
Mike
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1956199
11/23/15 12:03 AM
11/23/15 12:03 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Looking slick!
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1956238
11/23/15 01:05 AM
11/23/15 01:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
man I hope this works..... there are some killer top end deals out there just waiting for an available block.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1956241
11/23/15 01:10 AM
11/23/15 01:10 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Wow can't wait for results! You plan on dynoing it or just put in car when it comes off run stand?
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1960665
12/01/15 01:44 AM
12/01/15 01:44 AM
Kansas, Topeka
Kansas, Topeka
Update, it runs, no bad noises, cold oil pressure is 70-90 psi depending on RPM, hot(170F) oil pressure at idle (1150)is 40-45psi. oil pressure goes to 90+ when you bump the throttle. I did run it at 2500 to 3000 for 2 to 3 minutes to make sure the oil was gettingg back to the oil pan. So far the oil is nice and clean no water in the oil. The only thing I am concerned about is the amount of oil going to the top end, not much getting there. There is a leak on the front of the lifter valley cover I think that it's the set screws for the oil passages to the opposite side lifter galley, crank case vacuum is good. I took a video but it sucks so I am not going to post it. I plan on running it and working out some small problems and then go to the dyno.
Mike
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1960699
12/01/15 02:46 AM
12/01/15 02:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
hope the good news keeps on coming! the small block world could definitely use it! Any thoughts on the quality of aluminum used?
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1960855
12/01/15 12:37 PM
12/01/15 12:37 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Glad to hear that it is running! Is it in the car or on a run stand?
68 Barracuda Formula S 340
Re: 420cid build with a new Ritter Aluminum Block [Re: Bad340fish] #1960860
12/01/15 01:03 PM
12/01/15 01:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this block designed more for a dry sump than a
wet sump being that you had to come up with drain
backs... and as asked already... how is the quality of
the alum and porosity(if any)
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1961086
12/01/15 05:08 PM
12/01/15 05:08 PM
Kansas, Topeka
Kansas, Topeka
I have it running on a run stand, as far as the quality of the aluminum it is good there are a few spots that I can think of, one is in the core plug in the lifter valley. I had to tap them out to a larger size 1/2 NPT. We didn't find any porosity when we bored the block out to put the sleeves in and nothing when we decked the block. Yes I think the block is designed for a dry sump oil system.
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1961181
12/01/15 07:56 PM
12/01/15 07:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you drill a couple of holes in the dist area(at
the bottom) for your return oil.. I didnt recall seeing
the return pics
EDIT
Thanks for the info and hope it goes well for ya
and makes good power
wave
Re: 420cid build with a new Ritter Aluminum Block [Re: 69 lawndart] #1961182
12/01/15 07:56 PM
12/01/15 07:56 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Did you use a grooved lifter or bushin, so the oil could pass by 100% of the time. Because the oil galley is dead center of the lifter a groove someplace is necessary.. I used a grooved bushing. So that oil will pass by continuously
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
