high build primer questions #1933742
10/17/15 12:34 PM
10/17/15 12:34 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
I've got some summit 2k urethane high build primer that I'll be spraying onto my satellite in the next couple of weeks.
The data sheet says that the pot life is 15-20 minutes. Every other high build 2k urethane primer I've looked up online says it's an hour or more.
http://static.summitracing.com/global/im...ld%20primer.pdf
So I'm a little concerned that the stuff will be unsprayable after 15-20 minutes, which might not be enough time to get around the whole car. I plan on 2 or 3 coats.
Assuming the pot life is that short, should I plan to clean the gun out every 20 minutes? If the whole job takes 1+ hour (3 coats), should I clean the gun out during the process? Or just mix up more primer/hardener and keep going?
I've not painted with this stuff before so just trying to make sure I understand how it's supposed to go.
Re: high build primer questions [Re: Exit1965] #1933749
10/17/15 12:51 PM
10/17/15 12:51 PM
USA
hudsonhornet7x Offline
USA
I would say that if the pot life is that short mix just enough for 1 coat, and then mix a fresh batch for every coat you want to do. The little bit of time that it takes to mix should not cause a problem with the gun.
Re: high build primer questions [Re: Exit1965] #1933775
10/17/15 01:54 PM
10/17/15 01:54 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
It says dry time 120 mins, but spray pot life 20 mins? Seems odd to me, maybe just for compacts. grin bump
Re: high build primer questions [Re: jcc] #1933812
10/17/15 03:36 PM
10/17/15 03:36 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
My advice is if you are not sure if you can trust the pot time.
Mix a small batch and see what happens
20 minutes is a very short pot life.
Body filler can be that slow in cold weather.
Might call Summit or Global before you ruin your gun
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: high build primer questions [Re: Exit1965] #1933836
10/17/15 04:57 PM
10/17/15 04:57 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Summit's paint line is made by Kirker. All the tech sheets on their website shows 2k primer with a pot life of 1.5-2 hours at 70F. You will have plenty of time to do a complete. If you are really worried, reduce some with the slowest reducer you can. I've never seen anything with that short of a pot life at 70.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: high build primer questions [Re: Exit1965] #1937540
10/23/15 09:57 PM
10/23/15 09:57 PM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Well I sprayed it today. I have nothing to compare it to, but I guess it laid down OK using the Harbor Freight 94572 gun with the 1.4 tip. The sheet says 1.0-1.3, otherwise I would have tried the 1.8 tip.
I started sanding part of it already with 180 grit, and even after 3.5 hours (at around 78 degrees F), it's easy to sand. I'll pick it up again in about 1.5 days.
The pot life wasn't an issue. I was surprised how little material I used.. about 60 oz of primer/hardener for 2 coats of the car. I have a lot of primer left. I see a bunch of pinholes and sand scratches to address. My plan is to have that done, spot primed, and the car painted in a couple of weeks.
Re: high build primer questions [Re: Exit1965] #1939626
10/27/15 01:03 PM
10/27/15 01:03 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Where do you plan on having it painted?
Re: high build primer questions [Re: Exit1965] #1939805
10/27/15 06:56 PM
10/27/15 06:56 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Give even 2k primer time to cure before you start sanding{preferably days not hours}...The longer the better you don't want any sand scratches to reappear... The manufacturers info on "can be sanded within X time" is for a shop to get it out the door not for an award winning,smooth paintjob... twocents
Re: high build primer questions [Re: mopowers] #1940093
10/28/15 02:07 AM
10/28/15 02:07 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
I'm going to paint it myself. I'm going to use Kirker single stage urethane in an off white.
Re: high build primer questions [Re: herkamer] #1940192
10/28/15 08:58 AM
10/28/15 08:58 AM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Single stage is Kirker and 2 stage is Sherwin Williams
Re: high build primer questions [Re: Exit1965] #1940321
10/28/15 01:24 PM
10/28/15 01:24 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Nice! Post the results when you're done. I'd love to see the finished product.
