96 dodge pick up with no heat #194014
01/15/09 10:20 AM
01/15/09 10:20 AM
Canada
shadowauto Offline OP
Canada
I have a 96 dodge ram with 318 good running but it's has no heat temp gage read 95 bottom of rad is cold top is medium I run the engine with the rad cap of I see the antifreeze but no flow nothing move what could be wrong thanks Francis.
Re: 96 dodge pick up with no heat [Re: shadowauto] #194015
01/15/09 10:23 AM
01/15/09 10:23 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
How about starting with a new thermostat?
Re: 96 dodge pick up with no heat [Re: buildanother] #194016
01/15/09 10:37 AM
01/15/09 10:37 AM
Canada
Canada
I did that also I got the whole system flush I supect the water pump it's look original but never know thanks .
Re: 96 dodge pick up with no heat [Re: shadowauto] #194017
01/15/09 10:50 AM
01/15/09 10:50 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
If it s the water pump the engine would be over heating.
