My Son's 70 Duster
#1937431
10/23/15 06:43 PM
10/23/15 06:43 PM
Posts: 1,487 STL
cdstl
STL
We picked this car up a couple of weeks ago. Originally a 318 3 speed EV2 Gold Duster. It still has a 318 but now its a 4 speed and we have a standard bore 340 block sitting on the dolly. The plans are the following: Break the front end apart and pull the motor/trans for media blasting and paint. New brake lines, fuel lines and tank. Rebuild brake system. Clean, seal and detail the 318 and back in she goes. New wiring, heater box rebuild and DMT gaskets everywhere else. Headliner, package tray, front seat cover and a radio by March. He is going to be paying a $7K loan for the car and I will spring for the other work. Paint, other than the engine bay, will wait for another year and I told him to be ready to pony up half for that. Luckily a Mopar buddy is a paint guy but I am expecting it to be in the neighborhood of $5K for body and paint. We had a good first day. Unfortunately I have to be gone for most of the weekend so the motor/tranny won't come out until next week. That squirt can sitting where the battery goes is the "Magic Juice". half Acetone and half Transmission fluid. Good stuff.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: My Son's 70 Duster
[Re: cdstl]
#1938105
10/25/15 01:16 AM
10/25/15 01:16 AM
Posts: 8,140 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
I like it show us more I had one once (well I've had a few), my first car. I had it 17 years
[Re: cdstl]
#1938798
10/26/15 09:33 AM
10/26/15 09:33 AM
Posts: 64 Michigan
mopar4don
That squirt can sitting where the battery goes is the "Magic Juice". half Acetone and half Transmission fluid. Good stuff. What do you use it for? Why is it magic?
[Re: mopar4don]
#1938868
10/26/15 12:20 PM
10/26/15 12:20 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
That squirt can sitting where the battery goes is the "Magic Juice". half Acetone and half Transmission fluid. Good stuff. What do you use it for? Why is it magic? Penetrating oil. Mixed 50/50, works great.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#1940030
10/28/15 12:26 AM
10/28/15 12:26 AM
Posts: 1,487 STL
cdstl
STL
We got down to pulling the brake and fuel lines today. The only problem fittings are on the brake distribution block. I'm letting them soak overnight. The brake and fuel lines are in really good shape and I want to reuse them. After that we're taking to a buddy's place to blast the engine bay and hit it with some EV2. I'm thinking of going with Dot 5. Our buddy's 70 Roadrunner had a loose master cylinder bail last week and ruined his beautifully painted engine bay.
[Re: cdstl]
#1940218
10/28/15 10:23 AM
10/28/15 10:23 AM
Posts: 1,487 STL
cdstl
STL
Over-restored wiper motor. Too shiny but it's OK by me. Before... After...
[Re: cdstl]
#1941070
10/29/15 03:41 PM
10/29/15 03:41 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Cool project! Looks like a good bonding experience ahead.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: cdstl]
#1969073
12/13/15 06:49 PM
12/13/15 06:49 PM
Posts: 1,487 STL
cdstl
STL
Back on the ground. It's at my buddy's shop and it's raining today and probably tomorrow so we will more than likely get it home at the end of the week. Next the rear is coming out for detailing and new brake parts. Then the fuel tank and lines are going back in. Heater box, grill and oh yea the engine are next on the list. Hope to have it driving by the end of March.
[Re: cdstl]
#2034332
03/19/16 09:09 AM
03/19/16 09:09 AM
Posts: 1,487 STL
cdstl
STL
We've made some progress. The motor is back in with a mild cam and a 4 barrel. We got a different dash frame and had it blasted and powder coated fo $100. It's a light texture satin and seems to closely match the plastic glove box lock surround . There's a lot left to do beside the obvious but we should meet to goal of having it back on the road by the end of the month. Here it is moving under its own power again. Disregard the unequal stance in the rear, the front ride height isn't set yet. Under it's own power again... Duster shakedown
[Re: cdstl]
#2034758
03/19/16 11:08 PM
03/19/16 11:08 PM
Posts: 1,487 STL
cdstl
STL
It has been fun. Not too many hiccups but I can put up a post on Moparts and usually work it out in a couple of days.
[Re: cdstl]
#2035580
03/21/16 09:19 AM
03/21/16 09:19 AM
Posts: 1,487 STL
cdstl
STL
I agree on the blackout. The plan is to tear it apart in the fall and repaint it over the winter. It needs a trunk floor and they cobbled a DS quarter panel patch in that is fairly ugly from the inside. The fenders are fairly rust free but there has been some work done above the DS headlight. It's actually an EV2 Tor Red Gold Duster with a gold stripe. Not really sure about which graphics might end up on it, but that is a LONG way off. We got the front clip back on yesterday afternoon.
[Re: cdstl]
#2036934
03/23/16 01:51 AM
03/23/16 01:51 AM
Posts: 1,487 STL
cdstl
STL
Well it LOOKED like we were done thrashing for a while but we were wrong. I set the front ride height and we had it aligned. The problem was that there was coolant bubbling out from under the PS valve cover, again. I thought that we had a problem before with coolant coming in from around the head to intake manifold port so it was resealed. When I reran the engine I left the thermostat out and we didn't have a leak. Problem solved. Last night I put the stat back in so that we could run it today. We pulled the valve cover and found this. My machinist came over to take a look and I mentioned that there seemed to be fresh coolant below the valve springs of 4 and 6. I wondered if when he cut the spring pockets to fit my springs that maybe it got too thin. He has done this before to different heads. Well, after pressurizing the cooling system, water flowed out from under the 4 valve spring. These were a set of JY 714 heads. I'm having a set of 360 heads done and we will get a different set of locks and retainers that will fit with the springs. No cutting on Mopar valve spring seats. Now I know.
