Disc Brake Rotor Thickness, ok?? #193722
01/14/09 08:29 PM
01/14/09 08:29 PM
USA
Suregrip391 Offline OP
USA
I have a pair of disc brake rotors from a 73 Dart, they have surface rust on them from sitting, I was going to take them and have the bead blasted clean and then machined (turned). The thickness on them is .988" Does anyone know what they measure new? and what the minimum should be? Are these worth saving? Thanks!
Re: Disc Brake Rotor Thickness, ok?? [Re: Suregrip391] #193723
01/14/09 08:43 PM
01/14/09 08:43 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Don't know the typical thickness new.
Don't know positively the minimum, but I believe it to be .970"
There is a high probability that the minimum is cast into the hub somewhere under your rust...
Down to just a blue car now.
Re: Disc Brake Rotor Thickness, ok?? [Re: 68HemiB] #193724
01/14/09 08:47 PM
01/14/09 08:47 PM
USA
USA
Thanks for the info, actually I just looked at the autozone.com website and they list it all, the Nominal thickness is 1.010", the Minimal is .970", and the Discard thickness is .940" Looks like I am good to go! Appreciate the response though..:)
Re: Disc Brake Rotor Thickness, ok?? [Re: Suregrip391] #193725
01/14/09 11:02 PM
01/14/09 11:02 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Bead blast them and run them. I don't cut rotors unless I absolutely have to.
Re: Disc Brake Rotor Thickness, ok?? [Re: Jim_Lusk] #193726
01/15/09 07:35 PM
01/15/09 07:35 PM
USA
USA
Thanks Jim, I will have them bead blasted and see how they look. Appreciate the replies guys!
