Re: torque wrench question
[Re: mickm]
#1936260
10/21/15 05:37 PM
10/21/15 05:37 PM
RapidRobert
I didn't read thru the old thread posted but you torqued it to 40 then if another wrench started to move it at say 45 I'd be OK with that as breakaway torque is gonna be higher but with it turning (earlier) at 35 which is lower than the 40 you left it at then yes I'd want to get some answers. EDIT & the socket etc was all in a straight line especially at the end of the handle arc?
[Re: mickm]
#1936502
10/22/15 12:56 AM
10/22/15 12:56 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
5 pounds isnt much.My Snap on clickers are old one I bought at least 30 years ago the other about 25.Been used more than almost anyones here as I used them daily at work.Had them checked a few times IE recalibrated by the factory.They were never really out.The beam style if like my old old Craftsman thats at least 40 years old will register a bit higher than my clickers.Rocky
Chrysler Firepower
[Re: therocks]
#1936507
10/22/15 01:06 AM
10/22/15 01:06 AM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Yes it is. When you torque you need to stop as the bolt is moving - that is dynamic torque. When you are checking the torque (bolt6 is not moving)that is static torque which can be 10 to 20% higher than the dynamic torque in my experience. That means that in order to move a bolt after it has been torqued it can take 10 to 20% more torque to move than it did on the initial torque. In your case that means you were below 35 lbs if the beam torque wrench is accurate. I do a lot of work with torquing bolts.........
[Re: mickm]
#1937182
10/23/15 10:14 AM
10/23/15 10:14 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
As others have said, torque on bolt or nut is such an approximate way of estimating clamping force that plus or minus 5 is not something to be overly worried about, especially since just a bit of lubricant on threads can change the reading more than that. You can use an eight point star socket to directly test one torque wrench against another. For the cost of a calibration you can buy one of these using a 20% off coupon: http://t.harborfreight.com/12-in-drive-digital-torque-adapter-68283.htmlthe one I bought seems within the 2% advertised accuracy, and you can return it if not. By fixing a torque wrench horizontal in a vise, you can hang vertical weights off the centerpoint of the hand grip and do your own calibration. An accurate "fishermans scale" can also be used instead of weights to pull on the centerpoint of the grip.
[Re: 360view]
#1937239
10/23/15 12:40 PM
10/23/15 12:40 PM
RapidRobert
360view, unique/innovative info!
