Page 3 of 5 1 2 3 4 5
Re: How many towing race car with a 1/2 ton P.U.?? [Re: 5126brl No more] #193530
01/15/09 09:55 AM
01/15/09 09:55 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
We tow with a 67 2A Land Rover short wheelbase and a rope.
Fortunately we have only needed to do this to get up our hill when I broke an axle shaft in the old 8-3/4. The clutch sure-grip got it home to the base of the hill but couldn't handle the incline.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: How many towing race car with a 1/2 ton P.U.?? [Re: David_in_St_Croi] #193531
01/15/09 10:03 AM
01/15/09 10:03 AM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
My setup:
3/4 ton Cummins Turbo Diesel 5 speed
Re: How many towing race car with a 1/2 ton P.U.?? [Re: 5126brl No more] #193532
01/15/09 10:18 AM
01/15/09 10:18 AM
long island new york
K
kingdust Offline
kingdust  Offline
K
Ihave a 98 ram 1500 club cab 4x4 long bed 5.9 magnum.I tow a 28 ft atc alum.enclosed trailer I bought the alum trailer so I wouldn't have to buy a new truck at the time.the trailer is 3500lbs unladen about 1000lbs lighter than a steel one.I upgraded the rear springs on the truck and run a kurt sway control. It tows great but I'm at the limit of my towing capacity about 8000lbs.with everything in the trailer I'm at 7800.car-quad-tools-fuel etc! I need to get diesel for the long hauls.I don't want to push it on long trips to PA up those long grades! But I can't afford a new one so I'm going to do a few upgrades to the motor for now.
LIFE IS A LESSON,YOU LEARN IT WHEN YOUR THROUGH!
Re: How many towing race car with a 1/2 ton P.U.?? [Re: kingdust] #193533
01/15/09 10:38 AM
01/15/09 10:38 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
08 3500 Dodge ram mega cab single wheel 6.7 diesel with air bags on the rear.
32' enclosed V nose.
Years ago I used a 1/2 ton to pull a trailer, and it was awful until I put air bags under it. I used a set off a big truck and rigged them on, and it was great from a stability stand point, but the brakes weren't really up to it, and the 350 chevy was tired. I still went any where I wanted to go, it just took longer, and I was more careful. I'd pull with a mini if it meant the difference between going and not though.
Re: How many towing race car with a 1/2 ton P.U.?? [Re: dthemi] #193534
01/15/09 10:51 AM
01/15/09 10:51 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
'94 Dodge 2500 4X4 diesel with 190K towing an 18 ft. open steel trailer (`1800#). Getting the weight adjusting bars this week
Biggest tow so far is a 4000+ van (short distance).
My usual is cars - 2600 race car to 3400 normal cars.
I really prefer to have more tow vehicle than needed after a few dumb youth moves. Also, Southern California is home to a lot of drivers who have no clue what is going on around them at 75 MPH. It's better to have a balanced rig with enough power and braking to deal with traffic and idiots than to try to drive safe and rely on others to do the same.
Re: How many towing race car with a 1/2 ton P.U.?? [Re: RodStRace] #193535
01/15/09 11:51 AM
01/15/09 11:51 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
05 Dakota Quad Cab 4.7L
1500# 16' trailer and 3000# Duster.
I have a wt. dist hitch and it tows great.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: How many towing race car with a 1/2 ton P.U.?? [Re: CJK440] #193536
01/15/09 12:03 PM
01/15/09 12:03 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
84 Blazer serves double-duty for vacations when
not towing 52 ft. stacker to the track.
Re: How many towing race car with a 1/2 ton P.U.?? [Re: S/ST 3040] #193537
01/15/09 12:49 PM
01/15/09 12:49 PM
Wow, and I thought others were crazy for towing with Dakota's!
Didja have to put helper springs on it?
Re: How many towing race car with a 1/2 ton P.U.?? [Re: S/ST 3040] #193538
01/15/09 12:54 PM
01/15/09 12:54 PM
Palm Springs, CA
GYM Offline
GYM  Offline
Palm Springs, CA
I had to tow my '71 GTX / 16' open car trailer with my '97 Land Rover Defender 90 (4.0 litre V8)once for a short distance.
Never again.
Super short wheelbase trucks and car trailers laden with heavy old Mopars don't mix!
'71 GTX 440+6 (Second Owner) '70 Road Runner 383 4spd (x 2)
Re: How many towing race car with a 1/2 ton P.U.?? #193539
01/15/09 12:58 PM
01/15/09 12:58 PM
S/ST 3040 Offline
S/ST 3040  Offline
You Moparts guys are much too polite. Over 40 hits before anybody commented.
I got that picture in an e-mail entitled "Class 3 Hitch" and LMAO!
Mine
Re: How many towing race car with a 1/2 ton P.U.?? [Re: S/ST 3040] #193540
01/15/09 01:23 PM
01/15/09 01:23 PM
2006 3500 Dodge Laramie four door 4 wheel drive single wheel rear, 3:73 gears, automatic, stock Cummins. Trailer is a 24 ft 10,000 lb. GVW Pace Shadow,trailer weighs around 8600 lbs when loaded hook to the truck going to the races, truck weighs around 8000 lbs hook to the trailer, 7500 lbs unhooked Truck and trailer stop nice, tows great, good power and econmy, 14 MPG to 9.5 MPG at or above 70 MPH 6000ft above sea level to 180 ft above sea level so far
Re: How many towing race car with a 1/2 ton P.U.?? [Re: Cab_Burge] #193541
01/15/09 02:13 PM
01/15/09 02:13 PM
Chicagoland
chargerron69 Offline
Chicagoland
85 ram 250 2wd with a 440 833O/D 4spd dana 3.54 16foot open trailer.
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: How many towing race car with a 1/2 ton P.U.?? [Re: chargerron69] #193542
01/15/09 04:04 PM
01/15/09 04:04 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
As long as you are under the max rating for the truck you're good to go. If you're over that weight then a nice govt employee could give you a ticket.
Where I live, the max is 10K (as indicated on the trailer tag, not the actual load) with a regular license, drivers with a a class 3 license (commercial license) can tow trailers rated higher than 10K.
Anti-sway devices are also required after a certain point (either length or weight, dont remeber)
Re: How many towing race car with a 1/2 ton P.U.?? [Re: six-barrel] #193543
01/15/09 04:38 PM
01/15/09 04:38 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I have a 2003 F-350 King Ranch, crew cab, long bed, 4x4, diesel, pulling an 18 foot open trailer…this truck tows really well, lots of torque. When I lived in Colorado, a diesel was a must if you towed anything with substantial weight (like my old camper). Now that I’m in Indy, I really don’t NEED the diesel anymore…but I like the diesel power too much to get rid of it.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: How many towing race car with a 1/2 ton P.U.?? [Re: 5126brl No more] #193544
01/15/09 05:24 PM
01/15/09 05:24 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Gettin it done with SLANT SIX power!
'84 D100, 833OD, 3.91SG.
Here it is with a 6000lb plus load. The '67 Hemi Charger is 4000lbs plus. Homemade trailer has 16' runners. slide in ramps, 30"x30"x60" tool box, approx wt 2000lbs.
Re: How many towing race car with a 1/2 ton P.U.?? [Re: B5 Bee] #193545
01/15/09 05:32 PM
01/15/09 05:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
all I have to say is you guys pulling enclosed trailers witha 1/2 ton are very brave. I wouldn't do it
Re: How many towing race car with a 1/2 ton P.U.?? [Re: Quicktree] #193546
01/15/09 08:43 PM
01/15/09 08:43 PM
City of Champions
P
Prostock Offline
Prostock  Offline
P
City of Champions
Me either, especially with how high the fines are here. They are again cracking down on trailers. Two years ago a wood chipper broke loose and killed two children and their father. This year a trailer with a quad on it broke loose and killed two people and hurt one very bad.
If you aren't 100% DOT legal (and that doesn't mean legal in your state, that means in ALL 50 states), don't come to PA. You most likely will get cited and the fines here are horrendous.
Re: How many towing race car with a 1/2 ton P.U.?? [Re: S/ST 3040] #193547
01/15/09 08:59 PM
01/15/09 08:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Mine
Vic, that Pic, has been around for awhile
I saw the humor in what you were doing and liked it. I think , are you sure that Blazer/ camper rig wasnt yours at one time mike
Re: How many towing race car with a 1/2 ton P.U.?? [Re: Prostock] #193548
01/15/09 09:38 PM
01/15/09 09:38 PM
Connecticut
5126brl No more Offline OP
Connecticut
I have been trying to find a site or place that list the towing laws.
I have a 24 ft. enclosed that is registerd and built for a 10000# limit.
I heard that some states are getting tuff so I wanted to re register it at a lower rate say 9k.
What is the info that the dot or police are going to use to verify my truck can pull the 10K trailer?
It is not listed on the door tag? In the ford towing guide I have it says with 3.73s I can pull up to 14000# with a load distributing hitch and I have one.
Re: How many towing race car with a 1/2 ton P.U.?? [Re: Sport440] #193549
01/15/09 09:38 PM
01/15/09 09:38 PM
S/ST 3040 Offline
S/ST 3040  Offline
I just got it a few days ago. I thought it was hilarious but, no not mine. It's a GM.
