2004 Hemi Ram trouble starting when below 40 out
#1933067
10/16/15 07:24 AM
10/16/15 07:24 AM
Posts: 59 PA
Big Mike
PA
I have a 2004 Ram 1500 with a Hemi. It's got about 75,000 miles on it. Last winter when ever the temps dipped below 40 I would have a hell of time starting it in the morning. It would crank but the engine just wouldn't turn or fire. Kind of like I was out of fuel. Then it threw the codes p0340 and p0335 Cam and crank position sensors. I replaced the crank sensor and the light never came back on. By this time winter was almost over it was warming up out and the truck began to start fine again. Well this morning it was 45 out and the truck didn't want to start for about 5 minutes then It finally did and the same 2 codes came up. Anyone else have this issue? I did buy the cam sensor lastyear just never put it in. Why would the crank sensor be throwing codes again now? Thanks for your help Mike
Re: 2004 Hemi Ram trouble starting when below 40 out
[Re: Big Mike]
#1933237
10/16/15 02:40 PM
10/16/15 02:40 PM
Posts: 59 PA
Big Mike
PA
Interesting. I don't think it's that because it was like 46 this morning when it happened.
[Re: Big Mike]
#1933386
10/16/15 07:56 PM
10/16/15 07:56 PM
Challenger 1
Cincinnati, Ohio
Plugs are stock. Supposedly good till 100k. I should probably look into that though. Our 05 hemi plugs in our durango are only good for 32K MILES, I've changed ours twice now so far, all 16 of the ba$tards. You want to monitor the voltage when your cranking...if it low it won't start. Always start there unless the car/truck needs a tune up. Good luck getting those plugs out...
[Re: burdar]
#1933401
10/16/15 08:11 PM
10/16/15 08:11 PM
Challenger 1
Cincinnati, Ohio
I wonder if it has something to do with the gas tank? This is a different problem but...My wife's Sebring with fill just fine in the summer. When it gets cold, gas spits back out the fill tube when full. We replaced a couple valves in the fuel system but it still does it. The only other pieces to replace aren't available separately. They come attached to a new gas tank. I know Chrysler has had problems with filling for a while. Maybe something in the tank...or a valve attached to the tank is causing the no start issue when cold? This is possible, imo. We did get a whole new gas tank in our 05 durango under a recall. Cost us nothing and we were second owners. It did just what you said no matter how slow you went at the end year round, every time split gas out. My wife will not put up with that. (thinking after the fact, maybe that's why it was on the dealers lot as a trade in with 46K miles on it?) Otherwise the vehicles has been great. Then I read on moparts about a recall on them. I called the dealer and they knew nothing about it. I called back about a month later and they knew all about it then and scheduled it in. Took one day and we had a whole new gas tank. I was surprised it took a whole tank to fix it? The wife fills the thing up and it fills great, no problem. She goes to work and the durango is leaking gas all over the parking lot at her work! She calls me and I swing by to look at it and it is leaking down from the top of the new tank. Call the dealer and they come pick it up with a roll back truck. The plastic fittings on top of the new tank got cracked when they installed the new tank, I was told. So we got a second new tank and alot less gas but they got it right the second time. Been fine for 5 years now. What a stupid thing to have to deal with.
[Re: Big Mike]
#1933465
10/16/15 09:30 PM
10/16/15 09:30 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Plugs are stock. Supposedly good till 100k. I should probably look into that though. What Challenger1 Said The 04 Hemi left the factory with standard copper plugs good for only 30,000 miles At 75,000 miles - I am not saying that's your issue , but a good place to start - No pun intended Aluminum Heads - 11 Years - Original Plugs = Reminds me , I should look into my 2011 now that I think about it
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Big Mike]
#1933506
10/16/15 10:50 PM
10/16/15 10:50 PM
Challenger 1
Cincinnati, Ohio
Not the gas tank because even when spaying starter fluid it wouldn't fire up. So I don't think it's a fuel issue. You're probably right. Your plugs are trashed and wires/boots and?,IMO. Especially if your spraying that in there.
[Re: Big Mike]
#1933837
10/17/15 04:59 PM
10/17/15 04:59 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
My 05 had intermittent crank/no start events when the crank position sensor started to fail. Use an OEM one.
I also agree you need to change your plugs, but it likely isn't the issue.
[Re: Big Mike]
#1933942
10/17/15 09:47 PM
10/17/15 09:47 PM
Blusmbl
Plymouth, MI
When it isn't starting, do you get a reading on the tach? Does the check engine light stay on or go out? On lots of vehicles if the check engine light stays on during crank it isn't seeing an rpm signal from the crank position sensor. I think I remember when mine acted up the check engine light stayed on when it was attempting to start.
[Re: Big Mike]
#1934521
10/18/15 10:41 PM
10/18/15 10:41 PM
Posts: 46 Ohio
blown71duster
Ohio
How difficult is the cam sensor to replace? It is a bolt in deal like the crank sensor , bolts in the timing cover on the passenger side behind the thermostat.
[Re: Big Mike]
#1934556
10/18/15 11:36 PM
10/18/15 11:36 PM
Posts: 59 PA
Big Mike
PA
