70 challenger underhood wiring to starter relay
#193270
01/14/09 03:11 PM
01/14/09 03:11 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Can someone help me out with what wires go where to the relay by the battery. It is a 70 converted to electronic ignition if that matters. Thanks!
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 70 challenger underhood wiring to starter relay
[Re: Silver70]
#193271
01/14/09 04:01 PM
01/14/09 04:01 PM
RapidRobert
large cable from battery positive to large stud on relay & another large cable on that same stud going down to(the large stud) on the starter. brown wire from the "sol" connector on the relay which has a flat piece on it with a little screw goes down to the starter solenoid terminal(the small one on the starter). yellow wire or yellow w tracer from the bulkhead goes to "ign" terminal on relay(angled male stud I believe) & "grn" terminal on relay goes to nss switch at the clutch pedal or the trans.
[Re: RapidRobert]
#193272
01/14/09 05:55 PM
01/14/09 05:55 PM
Silver70
Rust Belt, SW PA
