LINE LOCK ? #193141
01/14/09 11:05 AM
01/14/09 11:05 AM
Belle River
Q
QUIKFISH1850 Offline OP
Q
Belle River
Is a line lock a one way check valve or a soleniod
that stops the fluid my car was set up with the line lock on the rear wheels it works great but my buddy says it is wrong should be on the front?
Re: LINE LOCK ? [Re: QUIKFISH1850] #193142
01/14/09 11:19 AM
01/14/09 11:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its actually both(most), its a solinoid that closes
but it also has a pressure limit that if you go
higher than the limit it will let off some of that
pressure. I prefer them on the front for my burnout
process, other than that I dont use it
Also, alot of the designs allow you to push fluid
past the valve in 1 direction while the valve is
engaged/on, so if you have the valve hooked to the
rears and you press the brake pedal you might be
applying pressure to the rears and not know it
Re: LINE LOCK ? [Re: QUIKFISH1850] #193143
01/14/09 11:20 AM
01/14/09 11:20 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
A line lock is a solinoid that stops the fluid from being relesed. It's location depends on what you want to use it for. Placing it in the rear brake line you use it as a staging control and luanch when you release it. I have mine in the front line and use it for doing burn outs. Then there are people the run dual linelocks.
Re: LINE LOCK ? [Re: WILD BILL] #193144
01/14/09 01:22 PM
01/14/09 01:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I think it's illegal to have them on the rear per NHRA rules.
Re: LINE LOCK ? [Re: Quicktree] #193145
01/14/09 01:56 PM
01/14/09 01:56 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
It is leagal to use a line lock on the brake line going to the back (you install it backwards). If you want you can put it in the line going to the back brakes to BLOCK line pressure and in that case you activate it, then press the brake pedal and then do your burnout. That way to can release the brake pedal and roll out of the water.
In this case it wold be a good idea to use a "dead man" switch for the line lock to insure that it is not left on reducing your braking at the end of a run.
I know of several cars set up this way.
SRT DEMON ONE SEAT
Re: LINE LOCK ? [Re: Ron Silva] #193146
01/14/09 02:34 PM
01/14/09 02:34 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I sorta like the idea of being able to control your rollout during your burnout. It also gives you the ability to use it to run your brakes at the start line, as holding the rear brakes will normally hold the car, whareas holding the front brakes only, most cars will push through the lights. some may find this more consistant than a regular foot-brake starting procedure.
Thoughts?
Re: LINE LOCK ? [Re: QUIKFISH1850] #193147
01/15/09 09:18 AM
01/15/09 09:18 AM
Belle River
Q
Q
Belle River
Yes that is how mine works I use it to roll out of the box it works good for me that way but was not sure about the check valve coment my friend made still not clear cause half the responese say it is the other half say it isnt?
Re: LINE LOCK ? [Re: QUIKFISH1850] #193148
01/15/09 10:13 AM
01/15/09 10:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You would need to test it or look at the design to
see if its a check valve design. If it has a spring
between the soliniod and the valve its a check valve
design which most are. Also the manufactuer would
say it holds X pressure(about 2500 lbs). Also in
the design, if it has a slooping edge on the supply
side it will allow pressure to be applied while its
engaged.... its all in the designs for what you have
EDIT
You wont be abile to see the differences in the outer
looks
Re: LINE LOCK ? [Re: MR_P_BODY] #193149
01/15/09 03:17 PM
01/15/09 03:17 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
If you want to use a Valve to BLOCK rear line pressure they do make valves (line lock type) specifically for this purpose. They are used on circle track cars to get them to turn into corners. They block brake pressure to a specific wheel in certain circumstancs.
SRT DEMON ONE SEAT
