Re: Cost of 900 hp in a N/A small block?
[Re: 408strokerdart]
#1989042
01/12/16 02:23 AM
01/12/16 02:23 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
This stuff is awesome, who would've thunk these little A motors would be crackin 900hp when they were bangin gears in their 340 Demons in 1971?
Mopar to the bone!!!
#1989256
01/12/16 02:56 PM
01/12/16 02:56 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I think 408stroker went 128 in Texas air with a powerglide. This is true, but to be fair it was killer air for here. Can not believe nobody is inquiring about the W8 top end in the for sale section that produced these results. That is some awesome parts at a good price, however it is an extremely narrow market... you have to have a narrow deck block and be willing to run very short pistons and rods or spin the beejebus out of a smaller displacment or find an unobtanium tall deck intake, you will still need a very expensive short block be it tall or short and you don't want to slap it on a stock block (well I do but I can afford it so thats a mute point). After someone spends $10,000 on that they are gonna think hard about an R5P7 ready to drop in with probably more potential. Someone will probably buy it at or close to you asking price but it may take a while.
#1989266
01/12/16 03:06 PM
01/12/16 03:06 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
"This is true, but to be fair it was killer air for here.
Can not believe nobody is inquiring about the W8 top end in the for sale section that produced these results"
I would love to take it off your hands but I am still knee deep in a Stratus build that seems to be never ending...
[Re: Al_Alguire]
#1989274
01/12/16 03:20 PM
01/12/16 03:20 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
These high horsepower high rpm engines appear to have lots of durability issues and not probably the way to go for the weekly racer. A few bonzi hits in the Fall and a couple of Mopar racers a year maybe
[Re: W5DART66]
#1989330
01/12/16 04:41 PM
01/12/16 04:41 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Once again years mean nothing to me. I love and respect these Big, small blocks but the bottom line is, HOW MANY PASSES, not years. Several (fast) small block guys I know are making the switch to big blocks and the simplicity of running mid to low 8's and staying together.
#1989333
01/12/16 04:49 PM
01/12/16 04:49 PM
Al_Alguire
Las Vegas
FWIW on the heads up car the engine was just pulled at 88 passes. Still leaks down fince and compression test was good as well. It is getting destroked to drop some weight for the class we run. It makes 1054hp is shifter at 9600 and goes through just under 10,000rpm. We have broken a few valve springs along the way but are happy with it's performance. Was being freshened this yeah anyway but just saying it ran its best ever pass at the last race last year. We prefer to freshen before something breaks, So while certainly not bracket race type deal it has held up quite well with lots of RPM and really thin rings.
[Re: Al_Alguire]
#1989448
01/12/16 08:17 PM
01/12/16 08:17 PM
Posts: 1,019 Finland
mafo
Finland
I have around 120 passes on mine now, nothing but normal maintenance,springs when needed, pac holds up very well, rods at 100 starts, now I'm going to put in new intake valves since I don't know how old they are, broke a rocker last summer, but thats it, 9000+ rpm
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: pittsburghracer]
#1989481
01/12/16 09:07 PM
01/12/16 09:07 PM
Posts: 41 PA
R5P7 Bantam
PA
These high horsepower high rpm engines appear to have lots of durability issues and not probably the way to go for the weekly racer. A few bonzi hits in the Fall and a couple of Mopar racers a year maybe I have just under 2000, yes 2000 runs (in 2.5 seasons) on my 358 and haven't so much as adjusted a rocker arm. And yes, I buzz it every run, both in the water and throughout the run....9200 thru the lights. As for a bracket engine, I can't think of a better way to go. Oh, and thats 176 mph at 1800 lbs. Mike
[Re: R5P7 Bantam]
#1989494
01/12/16 09:33 PM
01/12/16 09:33 PM
Posts: 20,160 PA.
pittsburghracer
"Little"John
"Little"John
PA.
These high horsepower high rpm engines appear to have lots of durability issues and not probably the way to go for the weekly racer. A few bonzi hits in the Fall and a couple of Mopar racers a year maybe I have just under 2000, yes 2000 runs (in 2.5 seasons) on my 358 and haven't so much as adjusted a rocker arm. And yes, I buzz it every run, both in the water and throughout the run....9200 thru the lights. As for a bracket engine, I can't think of a better way to go. Oh, and thats 176 mph at 1800 lbs. Mike . Pretty sure you and I talked about your engine at Norwalk as I had a chance to get one cheap. You took the time to explain some of the needed work and expense of this type of build and I decided against buying one
#1989876
01/13/16 02:17 PM
01/13/16 02:17 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Brett, those are impressive numbers!!
Just curious, how much lift, how much spring?
[Re: fast68plymouth]
#1990147
01/13/16 08:31 PM
01/13/16 08:31 PM
Posts: 1,784 PA
W5DART66
PA
Just curious, how much lift, how much spring? .900 .880 380 1100 350 980
#1990799
01/14/16 06:54 PM
01/14/16 06:54 PM
fast68plymouth
So. Burlington, Vt.
Using the fuel/bsfc numbers from the first pic, looks like 883.9 uncorrected for the 909 corrected......... That's about 2.8%. No fluff there.
#1990845
01/14/16 08:11 PM
01/14/16 08:11 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
R5P7bantam I'm with you R5's are built from the main web up for RPM.
Not fair to compare to LA engines.
But, in their defense. I ran W8R3 for over 15 years. Ran Arrington headed R block before that. They are not high maintenance. I put thousand of miles and passes on the Arrington. It was built for 1000 Mile events in craftsman truck and arca. The W8 nitrous combo had a couple bugs early. Nothing serious just learning. No one was doing 457+ cubes with this stuff then. Once we got oil returning to pan if was pure joy. The 421 was turned 9,200 regularly. Once a year valve springs and aluminum rods. We hotlapped every weekend.
Look at the dyno sheets. Brett now builds more torque in the 7K range so the RPM can be run lower. Plus PAC springs outlast the triples three to one. I built all three of my engines far cheaper. Gas was also $1 a gallon. Builders wanted $30-40K back then. Keep making excuses. Truth is it's a pretty darn good combo and 200# lighter than big blocks.
To change the vibe, don't even get me started on how affordable R5P7's are at 800hp.
