Louvered Hood How Too? #193078
01/14/09 09:55 AM
01/14/09 09:55 AM
3
340dart4spd Offline OP
Parts Problem
Parts Problem
3
Curious on how the process is Done??
Re: Louvered Hood How Too? [Re: 340dart4spd ] #193079
01/14/09 10:00 AM
01/14/09 10:00 AM
Branson, Southwest MO
Scat_Pack Offline
Scat_Pack  Offline
They remove the inner structure from teh item to be done, like truck hood whatever, and then it is put into a press, they have different styles of bits I think they call them that are set up for peaked or flat style louvers, and they are pressed one at a time, if you have a guy that really knows what he is doing he can do the freehand but most of the time it is a very time consuming process and they will measure almost every louver and mark it. I just had the hood done for my 49 mercury, had 356 holes punched cost was $1000. Jim
1941 ford coupe Chopped 6"
1966 VW Chopped 6"
1966 plymouth Belvedere II special order 999 paint code Petty Blue
1964 Dodge dart GT convertible
1971 340 Cuda
3 1969 Superbee's
"Anyone can restore a car, it takes a real man to cut one up!"
Re: Louvered Hood How Too? [Re: 340dart4spd ] #193080
01/14/09 10:34 AM
01/14/09 10:34 AM
Jacksonville Florida
elitecustombody Offline
with some practice you can do it yourself,all you need is a bead roller and set of dies for louvers or spend more $$ and buy the press
http://eastwood.resultspage.com/search?p...amp;submit.y=12
