SB Bypass Hose Fitting, 68 340, 1/2" NPT
#1928678
10/08/15 10:51 PM
10/08/15 10:51 PM
Posts: 1,443 Maryland
Dads426
Maryland
Having trouble finding a bypass hose fitting for a 68 340 intake. The later ones use the more commonly available 3/4" NPT fitting, but the early manifolds use a 1/2" NPT fitting. Hose ID is 1".
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
Re: SB Bypass Hose Fitting, 68 340, 1/2" NPT
[Re: Dads426]
#1928718
10/08/15 11:41 PM
10/08/15 11:41 PM
RapidRobert
speedway mtrs has a very nice selection of neckdown hoses/fittings. You might check em out online & likely could cut/trim one to fit your app. Is there a smaller ID 90 deg bend OE type bypass hose avail for the early pump/early intake?
[Re: Dads426]
#1928761
10/09/15 12:35 AM
10/09/15 12:35 AM
Posts: 13,585 md
mopars4ever
md
[Re: Dads426]
#1928889
10/09/15 10:28 AM
10/09/15 10:28 AM
Dads426
Maryland
You might be on to something about the hose size. Helping a friend out. He is going from an aftermarket intake that had the 3/4" fitting using the 1" hose to a stock intake with a 1/2" fitting. The water pump uses the 1" hose (ID measurement) that matches the aftermarket intake fitting, so I bet he has the wrong water pump. Dante's doesn't have the right one. Just checked an old 273 intake and it has a 3/4" bypass hose using a 1/2" fitting.
