2004 rumble bee cat back exhaust? #1923574
10/01/15 06:11 PM
10/01/15 06:11 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Wanting to put a Cat back exhust system on my 2004 Rumble Bee. Looking for one with a mellow tone-not loud. Must exit in stock location behind right rear tire. Any brand ecommendations? Thanks
Re: 2004 rumble bee cat back exhaust? [Re: sbcjd] #1924386
10/02/15 07:31 PM
10/02/15 07:31 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
If I were you I'd get a system that some Diesel guy has taken off of his truck and put it on. May need to do a little fabricating but it would be fairly minimal I'd think. Most Diesels have 3.5"+ mandrel bend exhaust systems. If not any of the brand name ones would be decent.
Re: 2004 rumble bee cat back exhaust? [Re: sbcjd] #1925523
10/04/15 12:33 PM
10/04/15 12:33 PM
Dysart,Pa.
K
kork340 Offline
kork340  Offline
K
Dysart,Pa.
I stuck an old 3 in glass pack I had laying around on my 04 with the stock resonator and tailpipe. Doesn't sound bad. Quiet while cruising and louder than stock when getting on it.
Re: 2004 rumble bee cat back exhaust? [Re: sbcjd] #1925536
10/04/15 12:57 PM
10/04/15 12:57 PM
Central NC
gch Offline
gch  Offline
Central NC
Or just replace the muffler only and be done with it.For ultra quiet until you hit the pedal do with a Dynomax VT.Or something like the longest Dynomax Ultraflo will not be obnoxious with the factory cat and resonator(if equipped).
Re: 2004 rumble bee cat back exhaust? [Re: sbcjd] #1925755
10/04/15 08:34 PM
10/04/15 08:34 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Don't go with the Magnaflow cat back system. I have it on my '05. It sounds great around town, but there is irritating drone around 2000 rpm (70mph), worse with a trailer. The last couple long trips I've gone on with it I've worn earplugs.
Corsa advertises no drone, I'd go that route if I bought a system again.
