Re: High temperature on 440
[Re: Pacnorthcuda]
#192351
01/13/09 08:45 PM
01/13/09 08:45 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I just built a stroker RB for my Dart, and it has 11-1 compression, RPM heads, mild cam (with lot's of duration), MSD ignition, etc. It has a 440 source alum water pump package, a Zirgo 16" fan (supposed to flow upwards of 3000 cfm ), and a Northern 26 aluminum rad. It currently has a 160* thermostat. It only has about 30 miles on the whole thing (da#m snow ). It too will run up to 210 or so idling in traffic, and come down 10-15* once moving again. I was told that a newly built engine will run hot, until it loosens up a little. I have no idea if this is true or not. Maybe someone here will chime in. I have also been told by a competent builder here that 210* is nothing to worry about. Personally I'd be happier if it ran at 180-190*. I'm gonna change my thermostat to a 180 0r 195, to see if that will make a difference, as it should keep the coolant in the rad longer. What thermostat do you have in there? codfish
[Re: kimber]
#192352
01/13/09 08:52 PM
01/13/09 08:52 PM
Posts: 6,418 Abilene, Texas
fastmark
Abilene, Texas
Unfortunately, I have experienced your exact some problem, times 2. It took a year for me to figure it out. I could not keep it cool. It was a brand new short block I bought when Mopar was selling off their surplus stuff in the early 80's for cheap. Later, a friend had the same problem that we could not fix. He bought the 440 block from wrecking yard out of a motor home. Both of these block were 77 or 78 blocks. Not many knew about this problem and there was no Moparts to ask. Both of these motors had 906 heads on them. I did some research and found that later motor home blocks had extra cooling holes on the surface of the block that mated with two holes in the head that were close to the spark plug. The holes met above the spark plug and help cool it. The heads are regular 452 but are machined different. They have the extra holes to mate the block and use the smaller tapered spark plug the the Chevy's do. We changed the block on my buds and fixed the problem. I found a motor home block that had a freeze crack and bought it for the heads so I finally have a complete MH motor now. That is why I know what the heads look like. My Dad almost bought a 78 MH for the deer lease and when we drove it, it got hot very quickly. I pulled the bonnet and you guessed it, one MH head and the other a freshly painted 906. I told him what the deal was and he said," no wonder it takes two different spark plug for each side." I do not know how to tell a MH block without looking at the surface where the head bolts to. I still have it at the shop, but it has the heads already installed.
[Re: fastmark]
#192354
01/13/09 09:12 PM
01/13/09 09:12 PM
RapidRobert
You can go here www.moparchat.com then scroll down to & click on circle track chat & peruse Sanborns cooling mods(it'll take several hours)that are in a stickey at the top of the page which will work for BB & SB & will enable you to do this(extra cooling holes) mod(& better) to any block/heads.
[Re: kimber]
#192355
01/13/09 09:15 PM
01/13/09 09:15 PM
Posts: 30,454 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Down here in Florida I'm not running a thermostat. What temperature thermostat should I use, and how will it help me?
You NEED a stat in-there. Problem solved.
