TWIN TURBO 1800+HP Dodge Dart Swinger
#1921294
09/28/15 05:01 PM
09/28/15 05:01 PM
Posts: 7,143 my own world
theraif
my own world
Re: TWIN TURBO 1800+HP Dodge Dart Swinger
[Re: theraif]
#1921355
09/28/15 06:38 PM
09/28/15 06:38 PM
Posts: 200 AB
Efidart
AB
Has a lot left in it with a new stator in the converter and some more tweaks. It's coming along though as that was our shake down of the car LOL.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: theraif]
#1921358
09/28/15 06:39 PM
09/28/15 06:39 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I could see you shifting in the video but the RPM sure wasn't changing.
68 Barracuda Formula S 340
[Re: Efidart]
#1921402
09/28/15 07:38 PM
09/28/15 07:38 PM
Posts: 368 michigan
turbo toad
michigan
Has a lot left in it with a new stator in the converter and some more tweaks. It's coming along though as that was our shake down of the car LOL. Out of all the cars i watched all week long it was the dart that in my opinion was what stole the show Keep it up
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: theraif]
#1921433
09/28/15 08:16 PM
09/28/15 08:16 PM
Posts: 9,865 MI, usa
dvw
MI, usa
[Re: theraif]
#1921511
09/28/15 10:53 PM
09/28/15 10:53 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Love it! Especially the Dingle-balls!
[Re: theraif]
#1921995
09/29/15 08:09 PM
09/29/15 08:09 PM
Posts: 200 AB
Efidart
AB
I'm running a Turbo 400 behind it with a gear vendors, I had a 727 on old combo but it could never hold the power back on the trans brake and killed clutches often. I also appreciate the ability to walk.
The part that broke was a billet steel front clutch hub from coan. Trans builder said he has only seen one other break and usually the shafts break first.
Going to tear into the trans more as some of the steels were seeing some heat, need to turn up the line pressure. The converter and trans change should put the power its making to the ground (around 2K rwhp without too much boost). Shave some good time off to where I think it should be.
I run a 3.40 9.5" Pro gear in the back with 40 spline axles.
Also need to drop the top 4 link bar one hole I'm thinking to give it a little more bite out of the hole too.
[Re: theraif]
#1922051
09/29/15 09:46 PM
09/29/15 09:46 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Congrats on drag week, loved having a Mopar to follow.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: theraif]
#1922151
09/29/15 11:39 PM
09/29/15 11:39 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Way keep your head in the game and trudge on man!
Mopar to the bone!!!
[Re: theraif]
#1922189
09/30/15 12:14 AM
09/30/15 12:14 AM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
Badazz! Same car since 15 years old. I love this. Good luck!
[Re: theraif]
#1922192
09/30/15 12:17 AM
09/30/15 12:17 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
They had a facebook page...and were updating it during the event? Man, I'm so stuck in the stone ages! That Dart is awesome, and so were the entire group of guys hanging around it!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: theraif]
#1922340
09/30/15 10:13 AM
09/30/15 10:13 AM
Posts: 368 michigan
turbo toad
michigan
Efidart if you dont mind sharing alittle info what size rear tire are you planting to the pavement? Also whats your launch rpm and boost psi,and lastly all in boost psi?
Im in the process of building a tamer version of what you guys have in the dart. Im hoping my junk will make around 1200rwhp on about 12psi. But only time will tell
Thanks in advance
[Re: turbo toad]
#1922344
09/30/15 10:22 AM
09/30/15 10:22 AM
MoparBilly
Phoenix, AZ
Not sure exactly TT, but it's big!
[Re: theraif]
#1922348
09/30/15 10:33 AM
09/30/15 10:33 AM
Posts: 368 michigan
turbo toad
michigan
Thanks moparbilly ill add those pics to my archive. Man that dart leaves hard! Sorry to hear about your accident will hope for a speedy recovery
[Re: theraif]
#1923051
10/01/15 04:49 AM
10/01/15 04:49 AM
Posts: 200 AB
Efidart
AB
Thanks for the kind words, the car has always been a work in progress. I used to run a single 118 mm turbo before with victor heads on the same shortblock, made 1550 rwhp and ran 7.90 all day with ease.
Hoping to get a 1.15-1.18 short time out of it when its turned up. I need to add more bite to the car off the line as it spins before it lifts the tires on initial hit. Usually was launching at 4800 and 4-5lbs boost and it seemed to like it there, 5000 is a little much.
Tires are 33x16-15 hoosiers, I've also ran the 33x18.50 ET streets with good results also.
All in boost didn't matter between 14-20 lbs for ET. It drove through the converter faster with 20 lbs so we just left it around 17-18 so it didn't put too much heat into the trans. Will be nice to see RPM drop and it to pickup ET and MPH when it actually starts locking up harder.
