Re: How much power will I lose?
[Re: RyanJ]
#192122
01/13/09 01:17 PM
01/13/09 01:17 PM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
Tom you have Domes in that thing? +4.5 CC domes?
They are 4.85cc domes, 0 deck, .040 thick gaskets with 4.080 bore. 4.045 cylinder bore, chambers are 67cc
[Re: a408swinger]
#192124
01/13/09 01:48 PM
01/13/09 01:48 PM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
Bigger horsepower differences are seen at lower compression levels with a bump up or down thaN with already high compression levels.
IE...Going from 9 to 1 to 10 to 1 will generally net a bigger positive gain than from 13 to 1 to 14 to 1.
My guess, in your application is probably 20-30 horsepower or so. Likely 8 to 12 or 14 hundreds difference in ET.
[Re: RyanJ]
#192125
01/13/09 01:51 PM
01/13/09 01:51 PM
a408swinger
mopar addict
mopar addict
South Carolina
Has piston to valve clearance been checked yet?
Not yet, waiting on rings and then I can assemble the short block and mock it up and check it.
