Refreshed 440 sounds like a diesel - video
#1920764
09/27/15 06:35 PM
09/27/15 06:35 PM
Posts: 282 Northeast MA
Charger446
Northeast MA
A few weeks ago I got the 440 running again in my Charger. I am putting off having a motor built for a few more years so I figured Id try to get away with a refresh of my motor. The motor was running well when parked 15 years ago. The cylinders looked ok so I just honed them with a flex ball and put new rings and bearings. The pistons had a few scratches in them but the machine shop who loosened them up on the rods thought they were ok. I had a few pistons that felt tight on the rod so I had them clean and re press them. The car was an automatic before, now a 4 speed, changed the heads to Edelbrock RPM, same intake and carbs and headers. The rockers are stock stamped steel Mopar, same ones that came out along with the pushrods. I re used the cam and lifters, putting them all in the same spot. Cam is Mopar 284/484, its running terrible right now, blowing gray smoke, about 8 inches of vacuum, not sure what the power valve is, but it smells very rich. I tried putting about 18 degrees initial timing, but it dieseled after shut off, didn't really drive it around to see if pinging, and with the noise, don't want to rev it up to high. I tried retarding the timing and the noise was still there. The noise follows the RPMS, almost sounds like an exhaust leak but it isn't. Not sure what I can do w/o taking off the intake. https://www.youtube.com/watch?v=sSS5oCcsRaQhttps://www.youtube.com/watch?v=rFh6mxFDMrE
Re: Refreshed 440 sounds like a diesel - video
[Re: Charger446]
#1920769
09/27/15 06:41 PM
09/27/15 06:41 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Sounds alot like valve train. Collapsed lifters or way too much pre-load. Too slow for rotating assembly parts.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Charger446]
#1920774
09/27/15 06:52 PM
09/27/15 06:52 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Definitely a valvetrain noise. What rockers are on it???
[Re: Charger446]
#1920775
09/27/15 06:52 PM
09/27/15 06:52 PM
Posts: 701 Northern California
lilcuda
Northern California
Sounds heavier than valvetrain to me. You say they pressed a couple of pistons off and back on. Did they measure the skirts afterwards? Pressing pistons off can distort the skirts.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: Charger446]
#1920780
09/27/15 07:05 PM
09/27/15 07:05 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
"Valve train noises occur at half of crankshaft speed so even if your ear can't tell whether the noise is happening at 700 rpm (raps per minute) or only 350 rpm, your eyes can. Hook the timing light to any one cylinder and watch the flash illuminate the timing mark. Stare at it for a while and see if the flash jives with the knock. If it does, then it is more likely to be rocker arms, pushrods, lifters, camshaft, cam bearings, timing chain and gears. If the noise seems twice as fast it is probably in the crank, mains, rods, rod bearings, wristpins and pistons."
[Re: Charger446]
#1920783
09/27/15 07:10 PM
09/27/15 07:10 PM
Posts: 11,689 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not going to be remedied by fiddling with timing, PVs, etc. Start taking it apart and looking. Pull the valve covers and bar it over. Look for something not right. Pull the plugs, spin it with the starter and listen. Pull the front and check cam timing, fasteners, etc. Been there. Sucks. Just have to start looking. First vid sounds like it has a miss to me along with the noise.
ETA...A mechanic's stethoscope could be very useful. I would limit the run time until I knew what it was.
[Re: a493demon]
#1920803
09/27/15 07:58 PM
09/27/15 07:58 PM
moparpollack
Lil Herman
Lil Herman
85086
Are the rocker shaft oiling properly?
[Re: Mr.Yuck]
#1921165
09/28/15 01:25 PM
09/28/15 01:25 PM
Posts: 1,051 The Great White North
RAMM
More than likely piston slap and or piston pin seized up. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: Charger446]
#1921259
09/28/15 04:03 PM
09/28/15 04:03 PM
Posts: 5,166 CT
GTX MATT
CT
The holes in the rocker shaft should face the valve springs.
Did you ever run the stock pushrods before with this cam? IMO the stock pushrods are likely too short.
[Re: GTX MATT]
#1921316
09/28/15 05:37 PM
09/28/15 05:37 PM
Charger446
Northeast MA
I did run these exact rockers/pushrods before on this motor, same cam, only difference was the heads. I ran stock iron heads previously, now running Edelbrock RPM.
[Re: Charger446]
#1921324
09/28/15 05:50 PM
09/28/15 05:50 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I did run these exact rockers/pushrods before on this motor, same cam, only difference was the heads. I ran stock iron heads previously, now running Edelbrock RPM. Did you check the lifter preload ? Was it making the same noise with the rollers ?
[Re: Charger446]
#1921333
09/28/15 06:03 PM
09/28/15 06:03 PM
6bblFLASH
N.E. Ohio
Maybe the pushrods are touching the heads side loading the rockers
[Re: Charger446]
#1921872
09/29/15 04:42 PM
09/29/15 04:42 PM
John_Kunkel
Rio Linda, CA
I figured the stock rockers would take the variable of the adjustable roller rockers out. Keep in mind that aluminum heads expand more than iron, if there is little/no preload on the lifters the preload will disappear as the heads expand away from the lifters.
