518 build #1919801
09/25/15 10:57 PM
09/25/15 10:57 PM
Atlanta, GA
mgoblue9798 Offline OP
Atlanta, GA
I am building a 518 non lockup hydraulic trans to live behind a 440 in my d100. Any recommendations for parts/upgrades/suppliers are welcome. I plan to use red alto clutches w/ more than stock in each drum and some sort of shift kit. Also plan on hd cooler and bigger pan. Any recommendations for additional upgrades are welcome. Truck will occasionally be used for towing.
Re: 518 build [Re: mgoblue9798] #1919921
09/26/15 03:36 AM
09/26/15 03:36 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
Do a search of the tech archives here on moparts. There have been several threads about using the 518 behind a bigblock. One member even used it in a truck.
I have 2 518's and an UltraBell sitting in the shed...waiting grin
Re: 518 build [Re: mgoblue9798] #1919964
09/26/15 10:28 AM
09/26/15 10:28 AM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Upgrade your servo pistons.
Re: 518 build [Re: mgoblue9798] #1920108
09/26/15 04:08 PM
09/26/15 04:08 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
i believe this is either Sonnex or perhaps DieselTrans advice on increasing ATF cooling flow to the overdrive section
