6 pak adjusting #1915515
09/19/15 08:39 AM
09/19/15 08:39 AM
NY
moparmatt0 Offline OP
NY
On a 1970 440 6 pak that is stock what jets in the center carb and where should you start out with the end carbs idle mixture screws.Thanks for the help.
Re: 6 pak adjusting [Re: moparmatt0] #1915530
09/19/15 10:01 AM
09/19/15 10:01 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
