71 Charger-Converting To Manual Disc Brakes-Prop. Valve
#191424
01/12/09 01:35 PM
01/12/09 01:35 PM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
I'm converting my 71 from pwr disc to manual disc brake. Can I use the existing proportioning valves or do I need to find one for a manual setup on this application? Thanks
'71 383HP FJ6 Charger SE
Re: 71 Charger-Converting To Manual Disc Brakes-Prop. Valve
[Re: 05dakota]
#191426
01/12/09 02:51 PM
01/12/09 02:51 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
No reason for it to be different. The only parts you should need are all at the master cylinder.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
