97 Ram sat for 6 years & now want to start it. Suggestions? #1912796
09/15/15 03:58 AM
09/15/15 03:58 AM
NW PA
V10nacuda Offline OP
NW PA
Have a 97 ram has been sitting for about 6 years outside. Figure I would siphon all the fuel from the tank with the hose and then disconnect the fuel rail and cycle the key a few times to flush any other garbage out of the fuel system after adding fresh fuel any suggestions?
Going to take it out to a buddies to make a field car out of it to teach my son how to drive
V10
Re: 97 Ram sat for 6 years & now want to start it. Suggestions? [Re: V10nacuda] #1913027
09/15/15 02:45 PM
09/15/15 02:45 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would probably just pour fresh gas into the tank and hit the key.
Re: 97 Ram sat for 6 years & now want to start it. Suggestions? [Re: V10nacuda] #1913054
09/15/15 03:34 PM
09/15/15 03:34 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
^^^^ This ^^^^
Re: 97 Ram sat for 6 years & now want to start it. Suggestions? [Re: V10nacuda] #1913128
09/15/15 05:02 PM
09/15/15 05:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Like I said the first time also change the oil and filter.
Re: 97 Ram sat for 6 years & now want to start it. Suggestions? [Re: stumpy] #1913347
09/15/15 10:40 PM
09/15/15 10:40 PM
IN
ahy Offline
ahy  Offline
IN
I think your plan will work. For a little extra insurance, you could pull the plugs and give each cylinder a little shot of oil and then turn it over by hand from the damper bolt to make sure everything is free and has some lube. Would not hurt to crank it with plugs out to get the oil flowing before starting also.
Re: 97 Ram sat for 6 years & now want to start it. Suggestions? [Re: V10nacuda] #1913405
09/16/15 12:09 AM
09/16/15 12:09 AM
NW PA
NW PA
Well I tinkered around with that thing tonight and couldn't get the hose down the gas neck so I put a fresh battery in it, 5 gallons of fresh gas. It fired up within a matter of a second or two and sat and idled like it was brand new I can't believe it..
Gonna stop and get oil and filter tomorrow.
Thanks for the tips
V10
