Made some test runs with the B1 Firebird
#1911503
09/13/15 07:18 AM
09/13/15 07:18 AM
Posts: 1,664 North Sweden
RT540
North Sweden
Finally took the car to a track. Now this was the last chance before the long winter here in North Sweden. It´s an small event 1/8 track mostly for street type cars, so there´s no prep. on the surface. About 12-14 feet rubber from tires at the start, then just asphalt. Loosed the rebound on the front Lamb struts and compr. on the Santhuffs, but I had to lift every run. Tires are old to, which did not help. Motor sounds great with only 32,5 degrees timing. Have had good support from both members here and the former owners of my car Lee and Mary Baltzell. Here´s a video of one run. https://goo.gl/photos/VMpyFyn6QvjHttus9Another : https://goo.gl/photos/poAv84BGQDNR2NKm6
Re: Made some test runs with the B1 Firebird
[Re: RT540]
#1911617
09/13/15 01:01 PM
09/13/15 01:01 PM
RT540
North Sweden
The air box is made from Lexan (polycarbonate). This one is made by me and have rivets with washers inside the scoop. It´s something I made -99 when I first raced the Coronet-69. I will be making a nicer one with glued corners instead. When bending 90° corners on Lexan, you need to have bigger radius or you will get lots of micro cracks. Best is to test of a piece of left over, before you bend it. Saw this on Yellow bullet, if you don´t want to build your own, which is not to difficult, if you have access to sheet metal equipment. http://www.yellowbullet.com/forum/showthread.php?t=567887
[Re: RT540]
#1912107
09/14/15 11:12 AM
09/14/15 11:12 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I dont know how far away you are but Tierp looks a freat facility. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: RT540]
#1912238
09/14/15 02:29 PM
09/14/15 02:29 PM
dogdays
