Page 20 of 32 1 2 18 19 20 21 22 31 32
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282610
04/02/15 06:18 PM
04/02/15 06:18 PM
new jersey
Black 69 Beeper Offline OP
new jersey
another view
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282611
04/05/15 12:06 AM
04/05/15 12:06 AM
new jersey
new jersey
driver quarter all welded.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282612
04/05/15 12:07 AM
04/05/15 12:07 AM
new jersey
new jersey
driver quarter, welds all ground.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282613
04/05/15 12:10 AM
04/05/15 12:10 AM
new jersey
new jersey
the rear body panel on both sides needed small pieces fabricated where the quarter was missing a tab to connect to the rear body panel.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282614
04/05/15 12:11 AM
04/05/15 12:11 AM
new jersey
new jersey
fabricated piece all welded.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282615
04/05/15 12:14 AM
04/05/15 12:14 AM
new jersey
new jersey
layout for vinyl roof molding. only there won't be a vinyl roof, it will be painted pewter!
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282616
04/05/15 12:16 AM
04/05/15 12:16 AM
new jersey
new jersey
pass vinyl top molding good to go.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282617
04/05/15 12:18 AM
04/05/15 12:18 AM
new jersey
new jersey
drivers side vinyl roof molding all good too.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282618
04/06/15 12:56 PM
04/06/15 12:56 PM
new jersey
new jersey
anyone know where i can get this clip? its for the side window trim and R/T specialties does not have them.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1282619
04/06/15 12:58 PM
04/06/15 12:58 PM
new jersey
new jersey
there are 8 if i am not mistaken and they hold this molding.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1817527
05/03/15 09:02 AM
05/03/15 09:02 AM
new jersey
new jersey
I will try and update a picture of whats been going on. not sure i am in love with this new format here. oh well. here goes. just got all my rear suspension parts. new hemi leaf springs, new u bolts, new shackles, rear shocks. everything has been painted and is ready to go.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1817530
05/03/15 09:09 AM
05/03/15 09:09 AM
new jersey
new jersey
just finished restoring my taillight housings, lens, and added the new gaskets.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1843301
06/07/15 10:59 AM
06/07/15 10:59 AM
new jersey
new jersey
No new pictures to post. I did get all my pieces for the disc brake conversion. rotors, calipers, bearings, etc, and all four shocks. i also ordered the passenger side door skin.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1859520
06/29/15 10:23 AM
06/29/15 10:23 AM
new jersey
new jersey
I finally got some motivation to get out in the garage. I got the rear body panel epoxy primed as well as the trunk jam and rear window shelf panel.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1859522
06/29/15 10:29 AM
06/29/15 10:29 AM
new jersey
new jersey
another shot. i plan to paint where the rear bumper brackets mount to the rear body panel before i put the car back on the rotisserie.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1910058
09/10/15 05:49 PM
09/10/15 05:49 PM
new jersey
new jersey
body has been completely epoxy primed with PPG DP90LF, inside floors have been coated with a spray able truck bed liner and the inside of the quarters have been texture coated with a spray able coating to match the OEM.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1910059
09/10/15 05:51 PM
09/10/15 05:51 PM
new jersey
new jersey
Rear shot
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1910061
09/10/15 05:54 PM
09/10/15 05:54 PM
new jersey
new jersey
Trans was sent out and completely rebuilt as well as the hurst shifter. trans will be painted when it installed.
Re: my 69 rr black, pewter int and pewter painted roof [Re: Black 69 Beeper] #1910966
09/12/15 08:53 AM
09/12/15 08:53 AM
Kentucky
fc7freak Offline
fc7freak  Offline
Kentucky
Keep up the good work. It is a long haul for most people but you will get there if you keep doing alittle along. I'm in the middle of a 71 Duster 340 resto myself. I am so slow I don't even post it on here but I keep getting alittle done at a time and it is adding up. Love your car!
Re: my 69 rr black, pewter int and pewter painted roof [Re: fc7freak] #1911006
09/12/15 10:45 AM
09/12/15 10:45 AM
new jersey
new jersey
Thanks fc7freak! it'll get there.
