Cracked header,,, repair question
#1908368
09/07/15 11:35 PM
09/07/15 11:35 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Noticed a small crack / hole in the number 3 header tube 4-5 inches down the tube from where it bolts to the head. You can feel a puff of air as the motor is running. Question, what is a easy way to fix this?. Does the header need to be removed from the car? Or can it be "welded up" on the car. It looks like it's pretty easily accessible. These are TTI headers that have been "coated". Not too concerned about overall cosmetic affect. Not sure how old the headers are ,,, I would guess about 10 plus years. Not sure how it happened unless it got beat up a little last time I had to change the starter which is always a PITA Thanks Doug
Re: Cracked header,,, repair question
[Re: 69CHARGERMD]
#1908374
09/07/15 11:41 PM
09/07/15 11:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Doug if you or the guy doing the welding it can be done on the car... but the coating needs to be ground off in that area.... but its much easier if they are off the car
[Re: 69CHARGERMD]
#1908380
09/07/15 11:53 PM
09/07/15 11:53 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
If there is a hole, It may be time for new headers. If they're thin enough to get a hole, they may be to thin to save. 10 years is a nice life span(depending on climate)
[Re: 69CHARGERMD]
#1908391
09/07/15 11:59 PM
09/07/15 11:59 PM
69CHARGERMD
KENTUCKY
Thanks Mike,,,,,,
Trendz,,,I was wondering if I should replace them as well
Is there anything I can wrap them with to finish the season ?? Or is this a bad idea ? Don't want a problem eg fire, etc.
[Re: TRENDZ]
#1908394
09/08/15 12:05 AM
09/08/15 12:05 AM
MR_P_BODY
Usually its the outside of the first bend that burns threw first... give that area a good push with your thumb to see if the metal bends or bust thru... if t does just buy a new set of headers... there comes a point that you just cant save them... that area that needs to be fixed is a strange area to burn thru first(if its a straight)
[Re: 69CHARGERMD]
#1908400
09/08/15 12:11 AM
09/08/15 12:11 AM
MR_P_BODY
Thanks Mike,,,,,,
Is there anything I can wrap them with to finish the season ?? Or is this a bad idea ? Don't want a problem eg fire, etc. Doug since you just want to finish the season... weld it up and take your chances that it wont burn thru in some other place
[Re: 69CHARGERMD]
#1908401
09/08/15 12:12 AM
09/08/15 12:12 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
If you have a shot at welding in place be sure nothing goes into your port if you burn through.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 69CHARGERMD]
#1908406
09/08/15 12:21 AM
09/08/15 12:21 AM
69CHARGERMD
KENTUCKY
Thanks Ozy
Mike,,,you are spot on,,,,it's right at the bend on the outside portion,,,,of the number 3 tube,,,,
I think I will replace them,,,this was something I hadn't seen before,,,,
Thanks everyone for the help
Doug.
[Re: 69CHARGERMD]
#1908562
09/08/15 12:22 PM
09/08/15 12:22 PM
Posts: 7,506 Az
Crizila
Az
Thanks Ozy
Doug. Probably thin there, as cracks from vibration normally occur at the header flange.
Fastest 300
[Re: 69CHARGERMD]
#1908746
09/08/15 05:25 PM
09/08/15 05:25 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I have found that when I start getting cracks/holes I can weld them up a few times but they are done. Once they start the holes continue because the heat cycles killed the metal.
[Re: markz528]
#1908751
09/08/15 05:46 PM
09/08/15 05:46 PM
MR_P_BODY
I have found that when I start getting cracks/holes I can weld them up a few times but they are done. Once they start the holes continue because the heat cycles killed the metal. The location his burnt thru is the hot zone in the tubes and the force of the flow going into the turn is the first area to burn thru... that whole area will be thin so when you start to patch it that hole WILL grow due to being thin and burning thru.. I have fixed some headers that had only a 1/2" hole in it but by the time I was done I had a 2" long patch on it due to it being paper thin
[Re: 69CHARGERMD]
#1908804
09/08/15 07:27 PM
09/08/15 07:27 PM
69CHARGERMD
KENTUCKY
Thx Paul,,,,, That might be a good option while I'm waiting on a new set of headers,,,,,might get me thru the rest of the season,,,,,,
[Re: 69CHARGERMD]
#1910234
09/10/15 10:29 PM
09/10/15 10:29 PM
MR_P_BODY
Doug... that metal got hardened and brittle.. is it fixable.. sure .. I'd weld it up.. but be prepared for cracks elsewhere... but I do the work myself so I put up with more BS than most.... any welder can fix that
[Re: 69CHARGERMD]
#1910250
09/10/15 10:47 PM
09/10/15 10:47 PM
MR_P_BODY
Thanks Mike, I have a good friend with very good welding skills. Going to take it out to him next week and see what he thinks. I sent him a picture, he thinks he might be able to cut that section out and repair it. Will keep you posted Doug... its up to him...but being that your just trying to get through the season.. I wouldnt even cut it out.. just weld it up... the most I would do is drill a 1/8" hole at the end of each crack and weld it up
[Re: 69CHARGERMD]
#1910363
09/11/15 01:44 AM
09/11/15 01:44 AM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Update header off. Looks to have crack adjacent to where tube was dented for plug clearance. Dang Doug sorry to see that. Its been so long but i bought those headers brand new to go with the 440 that was in the car when you bought it from me. I think i got the headers from mancini racing. Are you going back with a new set of the TTI or are you going to try a different brand?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
